Re: Power windows? [Re: 80arrow] #2451456
02/13/18 11:37 PM
02/13/18 11:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Also, They do not fit very well in an A-body. You can see how I had to mount it with the motor inside the door and the track on a pretty bad bind. Still doesn't work when I straighten the track out like I said earlier.
The only way to mount it straight would be to put it right where that big brace is inside the door, so that won't work.
Re: Power windows? [Re: 80arrow] #2451504
02/14/18 01:18 AM
02/14/18 01:18 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Now you probably know why the price has come way down from what they used to be.
They used to work, and now they don't, but they will sell the kits to you for cheap!
The electric window motors draw a lot of current, are your wires big enough? The wires to my window motors were at least 14 gauge, and may have been 12 gauge.
Its tough to beat the OEM stuff. The last one I used the power assembly from a 5th Ave, and swapped it into the location of the original unit.
Most of the modern stuff uses a centered beam that attaches to the top and the bottom of the inner door frame. A plastic track slides on the beam. The motor pushes the track up, or pulls the track down. The window channel attaches to the track. Gene
Re: Power windows? [Re: 80arrow] #2451759
02/14/18 06:30 PM
02/14/18 06:30 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Yes I tried big wires, tried with and w/o a relay. I even attached the electric motor directly to a fully charged car battery to eliminate all the wiring and the motor still seemed very weak.
I see that places like Gary Ball sell the same type of kit for triple the price. I wonder if they are better.
But I still didn't like how they fit in my door on a bind.
Re: Power windows? [Re: 80arrow] #2452563
02/16/18 02:36 PM
02/16/18 02:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I was doing some thinking and the ones I did were much more expensive. And the ones I used had the two drive cables separate and not linked together like yours. I see Spal sells a kit that sure looks like the one I used, and it does not include switches, which I specifically remember the ones I bought did not include switches. Of course they were triple the price of what you paid, which I do remember them not being cheap.
Re: Power windows? [Re: 80arrow] #2453074
02/17/18 03:32 PM
02/17/18 03:32 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Or you can take a C body power window assembly and swap arms from your A or B body onto the C body. I drilled mine and only added 1 lbs per front assembly.
Plus I used the C body harness.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
