2" TTi's with TF 240's #2450406
02/11/18 11:44 PM
02/11/18 11:44 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Has anyone had any experience with 2" TTI headers on a low deck b-body with Trick Flow 240 heads? Their website says that non-SR or -1 Indy heads need a tube modification. Do the 240's retain the same exhaust port height as a stock head?
Thanks.
I guess a good side note question would be if the 1&7/8 headers would be big enough for a 512 or if 2" would be recommended?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2450508
02/12/18 03:06 AM
02/12/18 03:06 AM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
I have a set of 2" tti's in a b-body with the tf 240's on a b motor, no issues. A side note, they were bought for a rb. I bought them used. not sure if that makes any difference.
Re: 2" TTi's with TF 240's [Re: moparlulu] #2450510
02/12/18 03:08 AM
02/12/18 03:08 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I think B and RB use the same part number for a tti 2". It shouldn't make a difference. luckluck
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2450883
02/12/18 09:17 PM
02/12/18 09:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
1 7/8" are plenty big.
'63 Dodge 330
11.19 @ 121 mph
Re: 2" TTi's with TF 240's [Re: GY3] #2450977
02/12/18 11:14 PM
02/12/18 11:14 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Hmmmmmm. Really?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2451015
02/13/18 12:08 AM
02/13/18 12:08 AM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
I'm only running 1.75" headers on my stroked low deck. Certainly not optimal but they were dirt cheap and the car runs 10.60's so I'm plenty happy with them.
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2451102
02/13/18 10:10 AM
02/13/18 10:10 AM
PA
Harry's Taxi 2 Offline
PA
Hmmmmmm. Really?
Yes
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2451162
02/13/18 01:20 PM
02/13/18 01:20 PM
AndyF Online content
AndyF  Online Content
1 7/8 should be fine with a 1.81 exhaust valve. Even 1 3/4 is probably okay coming off the head and then maybe a step up.
I asked TTI if they would make 1 7/8 to 2 inch headers rather than the huge 2 to 2 1/8 that they currently make but I just got crickets in return.
I think their headers are too big for the vast majority of cars out there but evidently they don't think so.
Re: 2" TTi's with TF 240's [Re: AndyF] #2451235
02/13/18 04:03 PM
02/13/18 04:03 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Mr. Prosport is good example of your thoughts!
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2451251
02/13/18 04:47 PM
02/13/18 04:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
On my lowly 383, 1-7/8 x 3 headers made a noticeable improvement in power over some 1-3/4 x 3 headers.
The results are in the tech archives.
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2451264
02/13/18 05:32 PM
02/13/18 05:32 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Mark and Bob have awesome cars and if they are good with 1 7/8, so am I. Andy and Dwayne chiming in as well tells me all I need to know. Thanks to all of you. 1&7/8 it is.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 2" TTi's with TF 240's [Re: OhioMopar] #2451525
02/14/18 01:43 AM
02/14/18 01:43 AM
Every RB or B motor I've put bigger headers on, primary and or collector, on the engine dyno or at the track like less exhaust resistance including a low compression pump gas 426 M.W that made more HP and torque on the engine dyno switching from Hooker A body 1 7/8x3.5 collector to 2 1/4 primary pipes with 4.0 collectors shock shruggy
The only reason that test occurred is the dyno operator/ owner didn't have a set of Mopar wedge dyno headers so he made them while that motor was on the dyno to test his against the Hookers I had. shruggy
on a street car with closed exhaust you probably won't feel or know the difference between the 1 3/4 to the 2.0 primary pipes with a stock type head shruggy
