2" TTi's with TF 240's
#2450406
02/11/18 11:44 PM
02/11/18 11:44 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Has anyone had any experience with 2" TTI headers on a low deck b-body with Trick Flow 240 heads? Their website says that non-SR or -1 Indy heads need a tube modification. Do the 240's retain the same exhaust port height as a stock head? Thanks. I guess a good side note question would be if the 1&7/8 headers would be big enough for a 512 or if 2" would be recommended?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: 2" TTi's with TF 240's
[Re: OhioMopar]
#2451015
02/13/18 12:08 AM
02/13/18 12:08 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I'm only running 1.75" headers on my stroked low deck. Certainly not optimal but they were dirt cheap and the car runs 10.60's so I'm plenty happy with them.
[Re: AndyF]
#2451235
02/13/18 04:03 PM
02/13/18 04:03 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I think their headers are too big for the vast majority of cars out there but evidently they don't think so. Mr. Prosport is good example of your thoughts! I'm only running 1.75" headers on my stroked low deck. Certainly not optimal but they were dirt cheap and the car runs 10.60's so I'm plenty happy with them.
[Re: OhioMopar]
#2451251
02/13/18 04:47 PM
02/13/18 04:47 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
On my lowly 383, 1-7/8 x 3 headers made a noticeable improvement in power over some 1-3/4 x 3 headers.
The results are in the tech archives.
[Re: OhioMopar]
#2451264
02/13/18 05:32 PM
02/13/18 05:32 PM
OhioMopar
Mt.Gilead, Ohio
Mark and Bob have awesome cars and if they are good with 1 7/8, so am I. Andy and Dwayne chiming in as well tells me all I need to know. Thanks to all of you. 1&7/8 it is.
