74 Fury driveline into 77 Monaco #2450900
02/12/18 09:40 PM
02/12/18 09:40 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
SO! BLUE-TOO 1 us 0!!! The donor 74 fury K car dimension from welded motor mount bracket on K frame to cross member is approx. 1.5 inches shorter than the 77 Monaco. Seems the 440 motor is 1.5 to 1.75 inch too far forward in the Monaco so trans mount , shift cross rod and driveshaft are not right. Anyone have a work around? Are 77 Monaco 440 mounts to motor different than 74 440 Fury? If not, will have to blow it back apart and cut/weld new frame mounts. Any C body experts out there? Thanks Phish
CALMED THE QUAKE!!!(AGAIN!)
Re: 74 Fury driveline into 77 Monaco [Re: Spyphish] #2450910
02/12/18 10:02 PM
02/12/18 10:02 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Pretty sure the dodge/fury were different wheelbase . . hence the difference . . .might only need a different driveshaft . . .
Re: 74 Fury driveline into 77 Monaco [Re: Spyphish] #2451100
02/13/18 09:48 AM
02/13/18 09:48 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
The Monaco is a small block car and I have learned the mounts are in a different location. Schumacher has a small to big block conversion mount which I have on the way. Just have to blow it back apart. Thanks
