SO! BLUE-TOO 1 us 0!!! The donor 74 fury K car dimension from welded motor mount bracket on K frame to cross member is approx. 1.5 inches shorter than the 77 Monaco. Seems the 440 motor is 1.5 to 1.75 inch too far forward in the Monaco so trans mount , shift cross rod and driveshaft are not right. Anyone have a work around? Are 77 Monaco 440 mounts to motor different than 74 440 Fury? If not, will have to blow it back apart and cut/weld new frame mounts. Any C body experts out there? Thanks Phish
