2006 ram vibrations #2448064
02/07/18 04:19 PM
02/07/18 04:19 PM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
anyone else experience a vibration in their 2006 Cummings 4x4 ram?
Re: 2006 ram vibrations [Re: dge330] #2448163
02/07/18 07:42 PM
02/07/18 07:42 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Is it lifted?
Re: 2006 ram vibrations [Re: dge330] #2449027
02/09/18 11:15 AM
02/09/18 11:15 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
while driving, at idle, loaded, unloaded, certain rpm, ......leaves a lot unanswered.
Re: 2006 ram vibrations [Re: dge330] #2449545
02/10/18 03:15 PM
02/10/18 03:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes big time, thought the injectors where going, ended up being the u-joint, were totally gone, i.e. no needle bearings left. A [censored] to replace since Dodge saw fit to put the injection clips to secure the cups, new ones have the c-clips. I just did the driveshaft, need to check the rest this spring. Should have known, my 92 diesel hammered them out every 30,000 miles and they where BIG joints.
Re: 2006 ram vibrations [Re: dge330] #2450022
02/11/18 01:16 PM
02/11/18 01:16 PM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
At around 65-75 mph unloaded.not too bad if I'm pulling a trailer.already changed ujoints.and removed balancing ring.rubber was a little worn.neither changed it
Re: 2006 ram vibrations [Re: dge330] #2450139
02/11/18 04:18 PM
02/11/18 04:18 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not sure if lower ball joints would cause it, they wear out fast. Just about everything on my 06 3500 has been replaced or rebuilt except engine. I thing all Dodges have tether straps hooked back to the dealer.
Any particular side, front-back?
Re: 2006 ram vibrations [Re: dge330] #2450367
02/11/18 11:16 PM
02/11/18 11:16 PM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
It's coming from the rear
Re: 2006 ram vibrations [Re: dge330] #2450420
02/12/18 12:10 AM
02/12/18 12:10 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Well I'd say start with the tires, check for out of roundness, knots, balance. Then work your way in, bearings, discs, shocks, springs, hangers, anything that could be broken or loose. Pinion bearing nut loose, bent driveshaft, work forward. Put on jacks, have someone spin it to 65-75 mph give it a visual for movement. My buddy's car had a bad vibe, he thought it was an out of balance engine that had recently been built, so I got it off the ground to look, one of the c-clips had come out of the u-joint and driveshaft was flopping around. It felt like a square tire. LOL
Re: 2006 ram vibrations [Re: dge330] #2450553
02/12/18 08:59 AM
02/12/18 08:59 AM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
new tires.nut is tight nothing loose.gonna put on jackstands and check drive shaft to see if it's bent next
Re: 2006 ram vibrations [Re: WO23Coronet] #2450753
02/12/18 05:17 PM
02/12/18 05:17 PM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
not lifted.just a stock 2006 2500 4x4 diesel
Re: 2006 ram vibrations [Re: dge330] #2450905
02/12/18 09:53 PM
02/12/18 09:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Did it viberate with the old tires?
Re: 2006 ram vibrations [Re: cudaman1969] #2451163
02/13/18 01:23 PM
02/13/18 01:23 PM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
yes
Re: 2006 ram vibrations [Re: dge330] #2451184
02/13/18 02:06 PM
02/13/18 02:06 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Is it possible the driveshaft is bent from removing the u joints?
Re: 2006 ram vibrations [Re: dge330] #2451375
02/13/18 08:57 PM
02/13/18 08:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just going to have to view everything while its up in the air and wheels turning.
Injector might be missing at speed, it fires 3 times each stroke, making a pulsing feeling-vibration. The common rail type have a lot of problems getting stopped up. Run some trans fluid (quart) each fillup, I use the wall mart chain saw oil in mine, can't remember the name right now.
Re: 2006 ram vibrations [Re: dge330] #2488390
04/26/18 06:19 PM
04/26/18 06:19 PM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
I think my output shaft bushing is bad . Put a dial indicator in the driveshaft and had .010-.020 in wobble on shaft . But the checked out put shaft and had about .050 side to side slop at the slip yoke. Ordered parts today .will update on outcome
Re: 2006 ram vibrations [Re: dge330] #2493088
05/07/18 08:19 AM
05/07/18 08:19 AM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
well output shaft bushing didn't help.still has a lot of play in front yoke.is it possible the yoke is worn?
Re: 2006 ram vibrations [Re: dge330] #2493113
05/07/18 10:49 AM
05/07/18 10:49 AM
md
md
I would think you would be able to notice if the yoke was worn that much when you had it out. I guess you could measure it and compare to a new one. BTW, The reason I asking if the driveshaft could have gotten bent when removing the u joints was because mine were so rusted that every u joint was a real pain to get out. I ended up just replacing the driveshaft because of all the trouble I had with removing them in fear that I knocked it out of balance.
Re: 2006 ram vibrations [Re: dge330] #2497086
05/17/18 08:21 AM
05/17/18 08:21 AM
North Carolina
dge330 Offline OP
dge330  Offline OP
North Carolina
drive shaft not bent I checked it with a dial indicator and it checked good .replaced slip yoke since it ad so much play in it and it helped tremendously . I also had a broken exhaust hanger and a bad right side tie rod had become very worn out where you could actually move the rod up and down about 3/16 of an inch .with all that being said after repairing and replacing all that the problem is gone.
Re: 2006 ram vibrations [Re: dge330] #2497700
05/18/18 09:33 PM
05/18/18 09:33 PM
md
md
Re: 2006 ram vibrations [Re: dge330] #2502066
05/30/18 01:20 AM
05/30/18 01:20 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
These trucks are famous for driveline vibration at highway speed. I worked at the dealer when these trucks were new and saw quite a few with this issue. Most of the time it was the driveshaft itself that was the issue. Could be either front or rear. Mark and Remove the front driveshaft and take it for a short test drive. If the issue is gone, reinstall it and clock both ends of the shaft from the original position. While it’s out inspect the u joints and lube the shaft bearing that no one ever seems to do. Inspect it for slop and binding. Also I see several bent or deformed rear driveshafts after u joint replacement. People usually heat the caps release the plastic that retains the caps, then while they are still hot, beat out the old u joint causing shaft damage.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
