DODGE TRUCK FRAME CRACKING @ STEERING BOX #2449895
02/11/18 01:09 AM
02/11/18 01:09 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I'm sure this has been discussed before, but a friend asked me tonight as he owns an 88. Is there a repair kit or just weld it?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Magnumguy] #2449897
02/11/18 01:14 AM
02/11/18 01:14 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
You need a factory frame brace.....common problem without one.
https://www.ebay.com/itm/1981-to-1993-do...ce/302607850056
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Magnumguy] #2449917
02/11/18 02:06 AM
02/11/18 02:06 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Hugh Jorgan] #2449947
02/11/18 03:39 AM
02/11/18 03:39 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I thought this was a mostly GM problem? I imagine big tires, steering dampers, extra leverage from lift-kits and the like would be hard on any factory setup. I cringe when I see people turning trucks lock to lock while the vehicle isn't moving. Worse yet, holding the power steering to the lock while the poor pump and belt are howling for mercy.
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Magnumguy] #2449951
02/11/18 03:59 AM
02/11/18 03:59 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My 01 2500 cracked, I v'd the cracked and welded it. Been good since and I run 315/75/16s on it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Magnumguy] #2449983
02/11/18 11:20 AM
02/11/18 11:20 AM
S.E.Ohio
S.E.Ohio
It's a 318 2 wheel drive. Doesn't see alot of rough use. Thanks for the tips.
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Magnumguy] #2450103
02/11/18 03:14 PM
02/11/18 03:14 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I just installed one of the braces to my '79 Power Wagon. No cracks and not getting a lot of rough use, but I like the extra protection. Nice brace and a pretty easy install.
Facts are stubborn things.
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Magnumguy] #2450141
02/11/18 04:28 PM
02/11/18 04:28 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
If it is already cracked, it will need to be repaired.
Drill the ends of the crack first in order to stop anymore cracking, weld it, then add the brace.
I have mechanical Aptitude.
I can screw up anything.
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: bboogieart] #2451111
02/13/18 11:04 AM
02/13/18 11:04 AM
scratchnfotraction Offline
this is best way to repair it.
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX [Re: Magnumguy] #2451228
02/13/18 03:45 PM
02/13/18 03:45 PM
ky.
K
kenworth_goose Offline
K
ky.
The red shortbed I just bought is cracked on both sides. That is the first time I've seen it on both sides. Just bought a second shortbed and I'm parting that one out So I'm going to do a frame swap and put a put a brace on the good frame. Think I'm going to make a trailer out of the cracked frame using the rear part.
