DODGE TRUCK FRAME CRACKING @ STEERING BOX
#2449895
02/11/18 01:09 AM
02/11/18 01:09 AM
Posts: 10,640 S.E.Ohio
Magnumguy
S.E.Ohio
I'm sure this has been discussed before, but a friend asked me tonight as he owns an 88. Is there a repair kit or just weld it?
Re: DODGE TRUCK FRAME CRACKING @ STEERING BOX
[Re: Magnumguy]
#2449951
02/11/18 03:59 AM
02/11/18 03:59 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
My 01 2500 cracked, I v'd the cracked and welded it. Been good since and I run 315/75/16s on it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Magnumguy]
#2450103
02/11/18 03:14 PM
02/11/18 03:14 PM
Posts: 15,826 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just installed one of the braces to my '79 Power Wagon. No cracks and not getting a lot of rough use, but I like the extra protection. Nice brace and a pretty easy install.
Facts are stubborn things.
[Re: Magnumguy]
#2450141
02/11/18 04:28 PM
02/11/18 04:28 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Is there a repair kit or just weld it? Thanks If it is already cracked, it will need to be repaired. Drill the ends of the crack first in order to stop anymore cracking, weld it, then add the brace.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2451111
02/13/18 11:04 AM
02/13/18 11:04 AM
Posts: 15,487 Florida
scratchnfotraction
Is there a repair kit or just weld it? Thanks If it is already cracked, it will need to be repaired. Drill the ends of the crack first in order to stop anymore cracking, weld it, then add the brace. this is best way to repair it.
