Stage 5 rockers/stock hemi valve covers #2449342
02/10/18 12:26 AM
02/10/18 12:26 AM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Need your help, as many of you may know, Stage 5 rockers will not fit under stock Hemi valve covers. I have read you can stack 2 sets of valve cover gaskets. I have verified that this is correct. I am purchasing .188 valve cover spacers from Mancini racing. I would like your input on the best gaskets to use on both sides of the shims. I suppose I feel better about having a shim in between two gaskets, like a windage tray.
Thanks Bob, by the way, it is a shame to conceal such good looking rockers under the valve covers.
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2449382
02/10/18 02:10 AM
02/10/18 02:10 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The best gasket I have found is a brand call Realgaskets, made here in Tennessee. They are molded silicone with a fiber glass core. I haven't noticed any leake, and they are reusable. Call 800-635-7325, and ask if they can be stacked like you were thinking. I was thinking about doing the same spacer thing with my motor, but haven't gotten around to it yet.
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2449396
02/10/18 02:58 AM
02/10/18 02:58 AM
What are you going to do about the spark plug tube lengths? work
Re: Stage 5 rockers/stock hemi valve covers [Re: Cab_Burge] #2449448
02/10/18 11:47 AM
02/10/18 11:47 AM
N.Y.
sixpacksteve Offline
N.Y.
Cab, thats a real good question!
Hell Hath No Fury Like Mine
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2449460
02/10/18 12:21 PM
02/10/18 12:21 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I just went through this with my Landy rockers hitting the stock valve covers. I dimpled the valve covers where they were hitting. With the wrinkle paint, you can't even tell. That helped, but there was still a place or two that just touched.
I used the Fel Pro Performance gaskets, which are 2 rubber/cork gaskets laminated to a wire mesh. They are really thick.
Then I put a washer under the spark plugs to space the tubes up. No more rocker to valve cover contact and no other problems. Probably not a perfect fix, but it seems to work.
And I would like to try the silicone gaskets mentioned above. The rubber/cork seal good, but need several re-torques.
Master, again and still
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2449501
02/10/18 01:43 PM
02/10/18 01:43 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Thanks for the response. I considered wacking, dimpling the valve covers but decided against it. I found the valve cover spacer on Mancini's web site and decided to go that route. I would like to use the thinnest but best gasket possible. I called Mancini and the spacer cannot be used as a gasket, so it needs to be sandwiched between two gaskets. The spacer is .188 thick. Mancini sell spark plug tubes, and o rings, that are 1/2 taller than stock.
I guess the big question now is what gaskets to use????????
Thanks again Bob,
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2449586
02/10/18 04:22 PM
02/10/18 04:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
There are chrome valve covers (66-69 style) that Stage V rockers will fit under but maybe you want the as delivered look.
2011 Drag Pak Challenger
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2449891
02/11/18 12:58 AM
02/11/18 12:58 AM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Thanks Rick I know that there are valve covers available that would clear the rockers but I am trying to use the original covers.
Thanks Bob
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2449957
02/11/18 05:16 AM
02/11/18 05:16 AM
P
PasiR Offline
PasiR  Offline
P
Use two gaskets and get longer tubes. I got tubes from Tim @ FHO.
Re: Stage 5 rockers/stock hemi valve covers [Re: PasiR] #2451090
02/13/18 05:33 AM
02/13/18 05:33 AM
California
mickm Offline
mickm  Offline
California
That's what I did.
Re: Stage 5 rockers/stock hemi valve covers [Re: mickm] #2451794
02/14/18 07:36 PM
02/14/18 07:36 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Originally Posted By mickm
[quote=PasiR]"the orange fun car" 540 Hemi 4 spd 3:54 dana
1 of 1 - only FK5 70 Road Runner that used to be a 383 auto now a 540 Hemi Six-Pack 4 spd in existence
Lets see some pics of that hemi six-pack.
I would like to have ran a six-pack but i didn't think it would flow enough for a hemi. I have the manual six-pack setup on my 383 presently.
What do you have for clutching and trans??
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2452078
02/15/18 12:05 PM
02/15/18 12:05 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Mopar had longer tubes available also, made for top fuel cars. Call a Top Fuel team, they will help. Most are super nice people. Maybe glue the Mancini spacer to head and use one gasket?
I like the mechanical 6 Pack too, just built one for my 440. I think if you calculate the airflow test pressure difference, the 6 pack is around 960 CFM? Changing the center carb from 350 CFM to a 500 CFM would help. Maybe I need one for my hemi??? Does the 6 pack work good on a short runner intake?
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2452388
02/16/18 12:29 AM
02/16/18 12:29 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am running the Stage V rockers under a set of ebag repop 68 black wrinkle valve covers with no problems with my crane solid roller cam and lifters...???
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2453005
02/17/18 12:46 PM
02/17/18 12:46 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Thanks for all the input. I purchase .188 spacers from Mancini Racing and I purchased Fel-Pro 1657's, thickness .094, to install on each side of the spacer. Plenty of seams for leaks.
Thanks Guys
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2453011
02/17/18 12:59 PM
02/17/18 12:59 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
After reading this I ordered some of the silicone gaskets from Realgasket. Hopefully these will stop the leaks I am always chasing with my stock covers.
Re: Stage 5 rockers/stock hemi valve covers [Re: Lee446] #2453056
02/17/18 02:35 PM
02/17/18 02:35 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Be sure to follow the instructions
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2453059
02/17/18 02:51 PM
02/17/18 02:51 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Lee646;
What was the problem you were having, stacked gaskets????
I was worried about stacked gaskets, so I am using a spacer, sandwiched between two gaskets, I was thinking about Real gaskets as well as Best gaskets out of Calif. Summit racing is just too easy. I thought Best Gaskets has a great head gasket.
Good luck with your leak..... both of us!!!!!!!!!!
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2453060
02/17/18 02:58 PM
02/17/18 02:58 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Rattrap; Just emailed you a pic of my Hemi six pac. Hopefully one of these days it will be mounted between the frame rails. It looks so good on the engine stand I feel like it should be put in my Living Room!!!! Hope my wife doesn't see this. As far as a tran; I can't drive a big block/Hemi with an auto. I kept the Torquflite, put it on the shelf, I will be running a Tremec 5 speed, 3.54 rear gears in a 67 GTX.
Mickey has the Roadrunner
Re: Stage 5 rockers/stock hemi valve covers [Re: tweeter1] #2453611
02/18/18 08:30 PM
02/18/18 08:30 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
No, I dimpled my stock black wrinkle covers and even though I straightened out the rails and used the good Fel-pros, it seems like I always find a drip somewhere. These silicone ones might be just what I need.
