Re: Stage 5 rockers/stock hemi valve covers
[Re: Cab_Burge]
#2449448
02/10/18 11:47 AM
02/10/18 11:47 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
Cab, thats a real good question!
Hell Hath No Fury Like Mine
[Re: tweeter1]
#2449460
02/10/18 12:21 PM
02/10/18 12:21 PM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I just went through this with my Landy rockers hitting the stock valve covers. I dimpled the valve covers where they were hitting. With the wrinkle paint, you can't even tell. That helped, but there was still a place or two that just touched.
I used the Fel Pro Performance gaskets, which are 2 rubber/cork gaskets laminated to a wire mesh. They are really thick.
Then I put a washer under the spark plugs to space the tubes up. No more rocker to valve cover contact and no other problems. Probably not a perfect fix, but it seems to work.
And I would like to try the silicone gaskets mentioned above. The rubber/cork seal good, but need several re-torques.
Master, again and still
[Re: tweeter1]
#2449586
02/10/18 04:22 PM
02/10/18 04:22 PM
Posts: 2,632 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
There are chrome valve covers (66-69 style) that Stage V rockers will fit under but maybe you want the as delivered look.
2011 Drag Pak Challenger
[Re: PasiR]
#2451090
02/13/18 05:33 AM
02/13/18 05:33 AM
Posts: 4,179 California
mickm
California
Use two gaskets and get longer tubes. I got tubes from Tim @ FHO. That's what I did.
[Re: mickm]
#2451794
02/14/18 07:36 PM
02/14/18 07:36 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
[quote=PasiR]"the orange fun car" 540 Hemi 4 spd 3:54 dana 1 of 1 - only FK5 70 Road Runner that used to be a 383 auto now a 540 Hemi Six-Pack 4 spd in existence Lets see some pics of that hemi six-pack. I would like to have ran a six-pack but i didn't think it would flow enough for a hemi. I have the manual six-pack setup on my 383 presently. What do you have for clutching and trans??
[Re: tweeter1]
#2452388
02/16/18 12:29 AM
02/16/18 12:29 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am running the Stage V rockers under a set of ebag repop 68 black wrinkle valve covers with no problems with my crane solid roller cam and lifters...???
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
