Need PN for for Dana rear axle seal #2448375
02/08/18 09:23 AM
02/08/18 09:23 AM
BDW Offline OP
BDW  Offline OP
I need to replace a leaky axle seal on my rear end.
Anyone know the correct part number, I see at least 2 listed, and they have different dimensions?
70 Challenger, Dana 60
Any tips on the R&R is appreciated too
Thx
Re: Need PN for for Dana rear axle seal [Re: BDW] #2448382
02/08/18 09:55 AM
02/08/18 09:55 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
70 challenger service manual here:
http://www.mymopar.com/index.php?pid=109
takes a minute to open
National Oil Seal 51098
save your old seal to compare to the new one, many parts stores list the WRONG seal, it will be a little to big (outside diameter)
Yeah, it's hopped up to over 160...
Re: Need PN for for Dana rear axle seal [Re: BDW] #2448406
02/08/18 11:21 AM
02/08/18 11:21 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
2852574 is the mopar number I came up with
Re: Need PN for for Dana rear axle seal [Re: mopars4ever] #2448519
02/08/18 02:40 PM
02/08/18 02:40 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hi,
the listing is for inner and outer, the outer is bigger dia. it is for the dust seal on bearing retainer plate
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Need PN for for Dana rear axle seal [Re: BDW] #2448527
02/08/18 02:52 PM
02/08/18 02:52 PM
md
md
2852574 is for the inner
Re: Need PN for for Dana rear axle seal [Re: BDW] #2448613
02/08/18 05:42 PM
02/08/18 05:42 PM
BDW Offline OP
BDW  Offline OP
Now I'm really confused, there are 2 seals behind the backing plate?
I thought there was a single seal that needs to be replaced when the axle is pulled?
Re: Need PN for for Dana rear axle seal [Re: BDW] #2448624
02/08/18 06:05 PM
02/08/18 06:05 PM
md
md
Re: Need PN for for Dana rear axle seal [Re: BDW] #2448625
02/08/18 06:08 PM
02/08/18 06:08 PM
md
md
https://www.ebay.com/p/1966-1973-NOS-Mopar-Dana-Rear-Axle-Bearing-Kit-3683966/1923660357 This axle bearing kit shows the outer seal that 440lebaron was referring to. It will be on the axle not in the housing.
Re: Need PN for for Dana rear axle seal [Re: BDW] #2449327
02/09/18 11:50 PM
02/09/18 11:50 PM
the thin steel one goes between the b plate & the housing end & the foam gasket goes on the other (outer) side of the plate against the axle retainer. You might fab an L hook with a slide hammer to pull the old seal straight out without nicking any area in the housing ID & HF I believe has a cheapie, not a dealbreaker but a caveat & it is a real good idea to have the plate off of the axle end before pulling it out (& gives you a simpler unobstructed work area there). first measure how far "in" the old seal was so you can drive the new seal inward that same distance. before installing the new seal, clean the housing end & generously swab some sealant around the housing ID at the distance in where the new seal will end up. get a round flat metal thick plate a hair less than the OD of the seal & a drift with flat ends & critical, get the seal started in square with several medium taps then drive it in the rest of the way with fairly hard hits makeing sure it stay square & if it gets tilted just put the drift on the high area of the plate & whack it there easy till it levels out. each whack increases the chances of the seal being distorted so accomplish this with as few strokes as possible within reason. also first put a generous amount of wheel bearing grease on the garter spring on the back side of the seal before starting to drive it in. If you mess up a seal just get another one at your parts house (they're fairly cheap) & this area must be sealed. confirm you have the right seals which ain't an issue from the Doc but parts house items are a different story, just hold the seal in the housing & see if there is just a slight interference. EDIT this is for an 8&3/4, I'm assuming the Dana is the same for this part of it.
Re: Need PN for for Dana rear axle seal [Re: BDW] #2449413
02/10/18 05:11 AM
02/10/18 05:11 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Thx
I wish I put that number down. When I did my Dana 60, everyone lists the 8-3/4 and Dana the same and my '69 Coronet, the Dana took a different size (outer diameter) axle tube seal.
Try this thread, I think it had the info:
https://board.moparts.org/ubbthreads/ubbt...e-question.html
Re: Need PN for for Dana rear axle seal [Re: 451Mopar] #2449467
02/10/18 12:32 PM
02/10/18 12:32 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
doctor diff has the parts and he will sell you the right one. His prices are very fair!
Re: Need PN for for Dana rear axle seal [Re: BDW] #2449591
02/10/18 04:42 PM
02/10/18 04:42 PM
BDW Offline OP
BDW  Offline OP
After digging through that other link and some web search, I'm going with National 481837.
As a bonus, RockAuto has these on warehouse close out for $0.95 each.
Re: Need PN for for Dana rear axle seal [Re: BDW] #2449756
02/10/18 09:08 PM
02/10/18 09:08 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
There are 3 different seals with 3 different widths for the Dana 60. My originals said National 34419 which I'm finding out was a Spicer part #.
473228 - 1.5000 x 2.5060 x 0.3125 (Double Lip)
481837 - 1.5000 x 2.5060 x 0.3750 (Single Lip) * Same width as my originals*
51098 - 1.5000 x 2.5060 x 0.4375 (Single Lip)
You don't know which ones you need until you pull out your original ones. That's what I'm finding out. I went thru this about 5 months ago.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2374994
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Need PN for for Dana rear axle seal [Re: 70sixpkrt] #2450003
02/11/18 12:34 PM
02/11/18 12:34 PM
BDW Offline OP
BDW  Offline OP
Thanks for the confirmation, the critical dimension I was worried about is the inside and outside diameters.
All 3 you listed will work with the only difference being a +/- 1/16" on the metal housing width.
Re: Need PN for for Dana rear axle seal [Re: BDW] #2774965
05/15/20 08:06 PM
05/15/20 08:06 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
These seals worked perfectly in me 1968 B body Dana 60.
Duralast 481837
I was trying to post a picture but I guess the days when it was easy are gone.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Need PN for for Dana rear axle seal [Re: Troy] #2774976
05/15/20 08:54 PM
05/15/20 08:54 PM
Duralast 481837
The 1968 and 1969 23 spline(or whatever splines they where)axles are smaller than the 1970, 1971 35 spline axles, which needs the bigger inner axles seals, I think scope
