#2446196 - 02/04/18 10:54 AM '72 D100 motor mount orientation
grancuda Offline
Loc: Central US
Putting a 360 in a '72 D100 & not sure which way the newer style motor with the safety built in is suppose to be set up. This is the way they fit by just sliding them in. I feel like they should be rotated 90* with the safety part to the back but if I rotate them 90* they are in a bind so maybe that answers my own question.
1967 Barracuda Formula S 383
1969 Dart Custom 2dr HT 400
1980 Macho Power Wagon LWB 318
2010 Ford Raptor 6.2L
#2446237 - 02/04/18 11:52 AM Re: '72 D100 motor mount orientation [Re: grancuda]
savoy64 Offline
Loc: colorado
in that first picture see that dimple-----i always thought the dimple located in the bolt slot.....
#2446619 - 02/04/18 10:31 PM Re: '72 D100 motor mount orientation [Re: grancuda]
moparmarks Offline
Loc: Western Colorado High Desert
Need to rotate the biscuit mounts 90*
71 RR A/G 4-sp Dana, 72 SSP 440, 72 Dart 5.9 4-spd, 97 DAKOTA, amoung others.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
#2447669 - 02/06/18 06:53 PM Re: '72 D100 motor mount orientation [Re: moparmarks]
RapidRobert Online   content
Loc: Lincoln Nebraska
As said they need to rotate 90 deg cuz you want the maximum contact between the mt and the isulator & for the nub round bump to locate/fit in the hole in the mts. what is binding? are the mts (& biscuits?) on the right side?
#2447989 - 02/07/18 10:40 AM Re: '72 D100 motor mount orientation [Re: grancuda]
scratchnfotraction Offline
Loc: Florida
frames will have 2 sets of holes for the mounts up till 87 also so make sure you are hitting the SB holes.
1 set is small block and 2 set is for a BB.
make sure mounts are on correct side of block lugs and biscuts need to turn 90* to line up correct.
sit the engine down on engine brackets without the biscuts to figure out which way the brackets bolt to engine block.
then raise engine install the biscuts.
valve covers are tight at firewall when correct.
IS the trans mount bolted up? if it is pulled forward enough it wont bolt up. the engine mounts are wrong if trans mount is off.
I set the trans mount first, then let the engine down on mounts
25,743 Registered Members
193,023 Topics
Who sells A-Body Rear Leaf Spring Rebuild Kits?
by vinnyd76
Today at 09:58 AM
Rich Edelebrocks
by moparjack44
Today at 09:37 AM
Converting a 12 volt battery to 16 volt
by Sammy
Today at 08:50 AM
What brand Ring & Pinion are you running in your 8.75 rear?
by vinnyd76
Today at 08:49 AM
