'72 D100 motor mount orientation
#2446196
02/04/18 01:54 PM
02/04/18 01:54 PM
Posts: 1,004 Central US
grancuda
Central US
Putting a 360 in a '72 D100 & not sure which way the newer style motor with the safety built in is suppose to be set up. This is the way they fit by just sliding them in. I feel like they should be rotated 90* with the safety part to the back but if I rotate them 90* they are in a bind so maybe that answers my own question.
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: '72 D100 motor mount orientation
[Re: moparmarks]
#2447669
02/06/18 09:53 PM
02/06/18 09:53 PM
RapidRobert
As said they need to rotate 90 deg cuz you want the maximum contact between the mt and the isulator & for the nub round bump to locate/fit in the hole in the mts. what is binding? are the mts (& biscuits?) on the right side?
