99 Ram 1500 Fuel Pump Question Please see pic!
#244784
03/06/09 08:35 AM
03/06/09 08:35 AM
Posts: 4,389 Kenmore, New York
InViolent
Kenmore, New York
Ram died driving to work on Tuesday. Had no choice but to have towed and mechanic tells me fuel pump went bad. Claimed he R&R Fuel Pump Assy. Charged me 365 for pump alone, 800$ total with tow and tax.
I looked under truck and was quite surprised to see no signs that this tank had been dropped.
Please see pic. This does NOT look like a "NEW" fuel pump...but what is that Gray fitting that the fuel line connects to? That almost looks new and not correctly seated!
UPDATE: I am working on uploading the pic.
Re: 99 Ram 1500 Fuel Pump Question Please see pic!
[Re: InViolent]
#244787
03/06/09 09:12 AM
03/06/09 09:12 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
A couple of thoughts,
Yes that does look like a new module assembly, The retainer ring will not come with the pump and is reused, The "gray thing" is not the fuel outlet, it is the rollover/vent valve. The Metal can on top is the filter/regulator and the fuel outlet is on the side of it. Most likely they lifted the bed to do the job (it is easier if the tank is full) look at the bed mounting bolts to see if they have been disturbed. That is not out of line for a OE pump assembly however that labor seems abnormally high, but that is somewhat subjective depending on the area of the country one is in.
Rick
Blown71X V2.0 under construction
71 Cuda 383 4-SPD (maybe for sale)
2010 Challenger B5 Classic
