Re: Hamtramck built 340 cars ?
[Re: Casey]
#2447468
02/06/18 05:20 PM
02/06/18 05:20 PM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
In addition to the casting date of the block, you should always also consider the engine final assembly date as well, especially since that number would be visible . As mentioned already, block casting dates can be months and in some cases a couple years prior to the cars SPD (although generally "most" fall within 4-6 weeks)however, the engines final assembly date is "usually" pretty tight against the SPD, usually 7 -10 days , but can of course be longer, or in some cases post date the cars "scheduled" production date , because the car did not get built on its actual SPD .
Greg
[Re: Casey]
#2448102
02/07/18 05:37 PM
02/07/18 05:37 PM
Posts: 5,306 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Just out of curiousity casey, what brand of car is we are talking about? Can you give us more info on the car...options/color..etc.
Plymouth Makes It!
