1970 340 Console Auto, Steering Column Lock Linkage #2447131
02/05/18 10:54 PM
02/05/18 10:54 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So I see some folks selling complete kits but don't often see anyone selling pieces. What I really need is the Column Lock Front Rod and a single Adjustable Rod Swivel Assy. Hate to buy a bunch of pieces I don't really need.
Does anyone offer these pieces new?
If I'm forced to search for used, whats the rod length?
Are these the same for all 340 floor shift Auto's?
Any other engines these are common to?
Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2] #2447228
02/06/18 01:12 AM
02/06/18 01:12 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I think the rod is the same for any steering column shift b or e body car..the swivels should be all the same..im putting together a set myself..it seems the L bracket mounted to the trans is different between a 904 and 727...all other parts are the same..at least that's what I found...
Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2] #2447302
02/06/18 10:10 AM
02/06/18 10:10 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
OK, maybe just need to keep searching and find someone who has those components to sell.
Do you have an overall length of the Column Lock Front Rod?
Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2] #2447446
02/06/18 04:34 PM
02/06/18 04:34 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Rod is about 14 inches...
You have a pm...
Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2] #2447740
02/06/18 11:29 PM
02/06/18 11:29 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
That’s perfect, really appreciate the pic and dimension
