#2447131 - 02/05/18 07:54 PM 1970 340 Console Auto, Steering Column Lock Linkage
AAR#2 Offline
Loc: Dry Heat AZ
So I see some folks selling complete kits but don't often see anyone selling pieces. What I really need is the Column Lock Front Rod and a single Adjustable Rod Swivel Assy. Hate to buy a bunch of pieces I don't really need.
Does anyone offer these pieces new?
If I'm forced to search for used, whats the rod length?
Are these the same for all 340 floor shift Auto's?
Any other engines these are common to?
#2447228 - 02/05/18 10:12 PM Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2]
AARCONV Offline
Loc: NEW JERSEY
I think the rod is the same for any steering column shift b or e body car..the swivels should be all the same..im putting together a set myself..it seems the L bracket mounted to the trans is different between a 904 and 727...all other parts are the same..at least that's what I found...
#2447302 - 02/06/18 07:10 AM Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2]
AAR#2 Offline
Loc: Dry Heat AZ
OK, maybe just need to keep searching and find someone who has those components to sell.
Do you have an overall length of the Column Lock Front Rod?
#2447446 - 02/06/18 01:34 PM Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2]
mccannix Offline
Loc: Ontario, Canada
Rod is about 14 inches...
You have a pm...
#2447740 - 02/06/18 08:29 PM Re: 1970 340 Console Auto, Steering Column Lock Linkage [Re: AAR#2]
AAR#2 Offline
Loc: Dry Heat AZ
That’s perfect, really appreciate the pic and dimension
25,743 Registered Members
193,027 Topics
This will tarnish the Patriots owner .....
by 70Challengerse
02/22/19 12:33 PM
Jegs/Summit Codes back out
by DusterKid
02/22/19 12:04 PM
Airtemp Infringing
by scatcity
02/22/19 11:32 AM
413 valve size
by als499
02/22/19 11:30 AM
