#2445484 - 02/03/18 12:28 AM FiTech - Throttle Cable & Kickdown Linkage?
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
My Father-in-Law is looking to install an FiTech setup on his '79 Li'l Red Express and I am wondering what challenges with throttle linkages we may run into.
If you have done this swap, were you able to retain the factory cable and kickdown linkage?
Or did you have to move to something like the Lokar setup for both?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2445584 - 02/03/18 09:41 AM Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda]
fourgearsavoy Offline
Loc: Rittman Ohio
Would the Edelbrock throttle lever bracket work for this shruggy They are made to adapt universal (most popular GM) to Mopar linkage.
Gus beer
Edited by fourgearsavoy (02/03/18 09:44 AM)
64 Plymouth Savoy
Dana 60
#2445596 - 02/03/18 10:01 AM Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: fourgearsavoy]
Azzkikrcuda Offline
Loc: North Dakota
FiTech has the Holly style throttle arm. I just set one up using the Holley throttle adaptor PN# 20-7.
The only Carbs I care about are under the hood!
#2445635 - 02/03/18 11:24 AM Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda]
Supercuda Offline
I want my mommy!!
Loc: up yours
Just to point out, the Edelbrock adapter and the Holley adapter are not interchangeable.
Don't be the exception.
#2445661 - 02/03/18 12:04 PM Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda]
Jerry Offline
Loc: Warren, MI
use the holley throttle arm adapter, I also switched to a cable operated kickdown linkage.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
#2445669 - 02/03/18 12:24 PM Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda]
dart4forte Offline
Loc: Mesa, Arizona
buddy of mine used the Edelbrock bracket. Aside for some alignment issues it works great. He will also have to make some adjustments to the throttle cable. He has a 79 Warlock with a bigblock
Edited by dart4forte (02/03/18 12:24 PM)
#2447133 - 02/05/18 07:56 PM Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda]
GTSDart340 Offline
Loc: Avondale, Arizona
I had to adjust the size of one of the holes in my Edelbrock bracket, but it works great. I have the factory throttle cable and kickdown linkage still in use.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
1972 Dodge D200 Adventurer - 318/727, eventually 440/518
2006 Dodge Magnum R/T "The Wagnum" - Hemi
2016 Dodge Durango Limited - 3.6
25,708 Registered Members
196,876 Topics
ShakerHood.Com
by RROD
01/23/19 03:10 PM
Small Chrome Plating System
by jim6346
01/23/19 02:09 PM
1968 Dart conversion from sedan to hardtop
by maximus
01/23/19 01:15 PM
Tire Diameter Selection
by gzig5
01/23/19 12:08 PM
