FiTech - Throttle Cable & Kickdown Linkage? #2445484
02/03/18 03:28 AM
02/03/18 03:28 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My Father-in-Law is looking to install an FiTech setup on his '79 Li'l Red Express and I am wondering what challenges with throttle linkages we may run into.
If you have done this swap, were you able to retain the factory cable and kickdown linkage?
Or did you have to move to something like the Lokar setup for both?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda] #2445584
02/03/18 12:41 PM
02/03/18 12:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Would the Edelbrock throttle lever bracket work for this shruggy They are made to adapt universal (most popular GM) to Mopar linkage.
Gus beer
64 Plymouth Savoy
Dana 60
Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: fourgearsavoy] #2445596
02/03/18 01:01 PM
02/03/18 01:01 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
FiTech has the Holly style throttle arm. I just set one up using the Holley throttle adaptor PN# 20-7.
The only Carbs I care about are under the hood!
Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda] #2445635
02/03/18 02:24 PM
02/03/18 02:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just to point out, the Edelbrock adapter and the Holley adapter are not interchangeable.
Don't be the exception.
Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda] #2445661
02/03/18 03:04 PM
02/03/18 03:04 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
use the holley throttle arm adapter, I also switched to a cable operated kickdown linkage.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda] #2445669
02/03/18 03:24 PM
02/03/18 03:24 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
buddy of mine used the Edelbrock bracket. Aside for some alignment issues it works great. He will also have to make some adjustments to the throttle cable. He has a 79 Warlock with a bigblock
Abe Lincoln
Re: FiTech - Throttle Cable & Kickdown Linkage? [Re: GoodysGotaCuda] #2447133
02/05/18 10:56 PM
02/05/18 10:56 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
I had to adjust the size of one of the holes in my Edelbrock bracket, but it works great. I have the factory throttle cable and kickdown linkage still in use.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
