‘65 a body 833 vs. say, e body
#2446579
02/04/18 11:33 PM
02/04/18 11:33 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
My son just acquired a ‘65 a body with an A833 in it. The questions are this: 1. What are the physical and performance differences between it and perhaps an e body 833? 2. Can it be built to take significantly more power than the 273 is putting to it?
I’m sure we’re in for an education on this build. It’s going to be a challenge to get it to where he envisions it.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: ‘65 a body 833 vs. say, e body
[Re: dfsmopars]
#2446588
02/04/18 11:54 PM
02/04/18 11:54 PM
Posts: 27,466 So Cal
autoxcuda
So Cal
It's Abody length with Abody length tailshaft, shifter location, and mainshaft.
The 65 and earlier trans' have a ball and trunion output flange.
The trans itself is not really significantly weaker than other 23 spline trans. Will take and warmed 273 or 340 or 360....
The ball and trunion is what people don't like about them.
Read the ID guide on the Brewers website.
[Re: dfsmopars]
#2446632
02/05/18 01:46 AM
02/05/18 01:46 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
That tranny could be one of the early 3.09 first gear trannys You can mark and align the input shaft and mark the front bearing retainer and then mark the flange on the output shaft and output shaft cover and put it in first gear and rotate the input shaft exactly one full complete revolution while counting the flange revolutions, it will either rotate a little over 2.6 revolutions or a little over 3.1 revolutions The reason I bring this up is the lower first gear ratio allows you to run a higher speed rear gear without bogging in first gear BTW, what does he want the car to become?
[Re: dfsmopars]
#2446756
02/05/18 12:10 PM
02/05/18 12:10 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
A light small block A body will be OK with the 23 spline box Like Cab said it probably has a 3.09 first gear so 3.23 or 3.55 rear gears would be a nice cruiser with some goo mechanical advantage down low. This ramps up the fun factor and the clutch disc will also thank you for it Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dfsmopars]
#2446778
02/05/18 12:39 PM
02/05/18 12:39 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Speedometer pinion hole in the tail shaft is smaller and unique to the early setup and pinion availability sux.
[Re: Cab_Burge]
#2446802
02/05/18 01:11 PM
02/05/18 01:11 PM
dfsmopars
Kentucky
Road course competitor.
[Re: dfsmopars]
#2446898
02/05/18 03:39 PM
02/05/18 03:39 PM
Cab_Burge
Is he going to stick with the 273 or put in a bigger SB? The reason I'm asking is the RPM drop between each gear on the wide ratio trannys may not help that little motor on a road course You should convert the tail shaft and output shaft to the later type that you can use a conventional slip yoke and U joint on that end of the driveshaft The E body tranny have a completely different longer tail shaft and out put shaft designed for the E body shifter mount The 1970 AAR Cuda and T/A Challenger and all the 1971 and later OEM 833NP trans. had a closer ratio gear set in them which may be better for road racing
[Re: dfsmopars]
#2446935
02/05/18 04:41 PM
02/05/18 04:41 PM
Supercuda
About to go away
About to go away
up yours
I suggest you go over to the cornering section and talk to them about using that A833 for road racing.
The straight line guys that predominate here won't know.
