‘65 a body 833 vs. say, e body #2446579
02/04/18 11:33 PM
02/04/18 11:33 PM
Kentucky
dfsmopars Offline OP
Kentucky
My son just acquired a ‘65 a body with an A833 in it. The questions are this:
1. What are the physical and performance differences between it and perhaps an e body 833?
2. Can it be built to take significantly more power than the 273 is putting to it?
I’m sure we’re in for an education on this build. It’s going to be a challenge to get it to where he envisions it.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: ‘65 a body 833 vs. say, e body [Re: dfsmopars] #2446588
02/04/18 11:54 PM
02/04/18 11:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It's Abody length with Abody length tailshaft, shifter location, and mainshaft.
The 65 and earlier trans' have a ball and trunion output flange.
The trans itself is not really significantly weaker than other 23 spline trans. Will take and warmed 273 or 340 or 360....
The ball and trunion is what people don't like about them.
Read the ID guide on the Brewers website.
Re: ‘65 a body 833 vs. say, e body [Re: dfsmopars] #2446632
02/05/18 01:46 AM
02/05/18 01:46 AM
That tranny could be one of the early 3.09 first gear trannys work scope
You can mark and align the input shaft and mark the front bearing retainer and then mark the flange on the output shaft and output shaft cover and put it in first gear and rotate the input shaft exactly one full complete revolution while counting the flange revolutions, it will either rotate a little over 2.6 revolutions or a little over 3.1 revolutions scope
The reason I bring this up is the lower first gear ratio allows you to run a higher speed rear gear without bogging in first gear up
BTW, what does he want the car to become?
Re: ‘65 a body 833 vs. say, e body [Re: dfsmopars] #2446756
02/05/18 12:10 PM
02/05/18 12:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
A light small block A body will be OK with the 23 spline box twocents
Like Cab said it probably has a 3.09 first gear so 3.23 or 3.55 rear gears would be a nice cruiser with some goo mechanical advantage down low. This ramps up the fun factor and the clutch disc will also thank you for it drive
Gus beer
64 Plymouth Savoy
Dana 60
Re: ‘65 a body 833 vs. say, e body [Re: dfsmopars] #2446778
02/05/18 12:39 PM
02/05/18 12:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Speedometer pinion hole in the tail shaft is smaller and unique to the early setup and pinion availability sux.
Don't be the exception.
Re: ‘65 a body 833 vs. say, e body [Re: Cab_Burge] #2446802
02/05/18 01:11 PM
02/05/18 01:11 PM
Kentucky
Kentucky
Road course competitor.
Re: ‘65 a body 833 vs. say, e body [Re: dfsmopars] #2446898
02/05/18 03:39 PM
02/05/18 03:39 PM
Is he going to stick with the 273 or put in a bigger SB?
The reason I'm asking is the RPM drop between each gear on the wide ratio trannys may not help that little motor on a road course work
You should convert the tail shaft and output shaft to the later type that you can use a conventional slip yoke and U joint on that end of the driveshaft up twocents
The E body tranny have a completely different longer tail shaft and out put shaft designed for the E body shifter mount scope
The 1970 AAR Cuda and T/A Challenger and all the 1971 and later OEM 833NP trans. had a closer ratio gear set in them which may be better for road racing scope
Re: ‘65 a body 833 vs. say, e body [Re: dfsmopars] #2446935
02/05/18 04:41 PM
02/05/18 04:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I suggest you go over to the cornering section and talk to them about using that A833 for road racing.
The straight line guys that predominate here won't know.
