360 mag and LA rear main seals #2446509
02/04/18 09:24 PM
02/04/18 09:24 PM
B.C. Canada
hankcrank Offline OP
B.C. Canada
Been racing RB blocks since the 70's and am building a small block this time so my knowledge is limited on the SB blocks.The Mag & LA rear mains have different part numbers yet when I compare the ones I pulled from either block they are the same in looks and size. Anyone have any experience with these seals?
Re: 360 mag and LA rear main seals [Re: hankcrank] #2446529
02/04/18 10:00 PM
02/04/18 10:00 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Maybe the LA seal is a bit different since they originally had a rope seal vs the Magnum having a rubber seal.If you pulled a rubber seal from each,possibly the wrong seal was installed into one of the blocks,LA in particular....Just a guess
RT
Re: 360 mag and LA rear main seals [Re: hankcrank] #2446768
02/05/18 12:23 PM
02/05/18 12:23 PM
can you post the part #'s, maybe that will give us some direction
