Page 1 of 3 1 2 3
trans case number on 69 cuda m-code cars #244557
03/05/09 11:05 PM
03/05/09 11:05 PM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
any guys or gals with m-code 69 cuda or darts cars that has the original trans so i can get the right number? i have two diferent # 2892093 or the one that came in a 69 383 cuda ,2892091. I don't know if they kept the trans and added the engine or engine trans as a package.
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244558
03/05/09 11:07 PM
03/05/09 11:07 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
the 093 is correct, the 091 is for a 383 4bbl with A/C
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: trans case number on 69 cuda m-code cars [Re: AZ_A12_BEE] #244559
03/06/09 12:11 AM
03/06/09 12:11 AM
fredericksburg,va
fredericksburg,va
az bee, do you hva a m-code a-body?
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244560
03/06/09 12:38 AM
03/06/09 12:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The m code a body used the 093 trans .
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244561
03/06/09 12:38 AM
03/06/09 12:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
he has one better , the M code B BODY
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244562
03/06/09 12:42 AM
03/06/09 12:42 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I'm looking at the Chrysler parts manual. All the 383HP/440HP B Body and bigger cars came with the 093. The Valiant/Barracuda/Dart with 383 4 BBL came with an 091 in them. It was considered an A727B as was the 093 trans. They do not show a 383HP or 440HP listing for an A Body? Only a 383 4 BBL. They just say that the Satellite/Coronet w/383HP and 440HP eng, the Chrysler w/440 HP and the Ply/Dodge except SW w/440 and HP engines had the A727B p/n 2892093. It seems like the M code should have had an 093 in it because it was behind a 440HP?
Re: trans case number on 69 cuda m-code cars [Re: RoadRunnerJD] #244563
03/06/09 01:03 AM
03/06/09 01:03 AM
fredericksburg,va
fredericksburg,va
it all depends if hurst just added the engine with the trans still in the car or they got engine and trans together from the factory. and by the way 69 a12s where just stock 440s with a good intake and carbs 70 got all the good stuff in the engine. but i stiil like em
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244564
03/06/09 01:06 AM
03/06/09 01:06 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 M-code a-bodies were assembly line built at Hamtramck, including drivetrain.
Re: trans case number on 69 cuda m-code cars [Re: 6bblgt] #244565
03/06/09 01:11 AM
03/06/09 01:11 AM
fredericksburg,va
fredericksburg,va
sorry you are wrong about that part because they couldn't bring the car down over the engine on the assembly line (to wide) so they farmed it out to the guys that built the 68 hemi cars. i have alot of paper on this
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244566
03/06/09 01:15 AM
03/06/09 01:15 AM
Warrenton, VA
Warrenton, VA
69 A12's were faster!
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244567
03/06/09 10:17 AM
03/06/09 10:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
70 got all the GOOD stuff ??? The heavy rods SLOWED the 70 down ...
Line up a 69 against a 70 and let the azz kickin' BEGIN ....
When it comes to 6pk cars , A12's are KING of the MOUNTAIN.
Where's Rhinodart , he can put this one to rest .
Re: trans case number on 69 cuda m-code cars [Re: RoadRunnerJD] #244568
03/06/09 12:11 PM
03/06/09 12:11 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
John, the 091 trans is for 383 4 bbl A/C cars, since M code A bodies cannot have A/C it would not have that trans in it even if the car started out as a 383 car and the 440 was put in by an outside vendor
Re: trans case number on 69 cuda m-code cars [Re: JohnRR] #244569
03/06/09 12:57 PM
03/06/09 12:57 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
70 didnt even get a fresh air hood or 4.10 Dana as standard equipment unless it was a 4 speed, also the 69 hood/aircleaner blew the 70 away as far as CFM to the carbs. Also a 69 M code B body is way faster than an M code A body.
Re: trans case number on 69 cuda m-code cars [Re: AZ_A12_BEE] #244570
03/06/09 02:03 PM
03/06/09 02:03 PM
Santa Cruz, CA
1969cudaman Offline
1969cudaman  Offline
Santa Cruz, CA
093
Re: trans case number on 69 cuda m-code cars [Re: AZ_A12_BEE] #244571
03/06/09 02:31 PM
03/06/09 02:31 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: trans case number on 69 cuda m-code cars [Re: 69CoronetRT] #244572
03/06/09 02:43 PM
03/06/09 02:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doooooh ....
Re: trans case number on 69 cuda m-code cars [Re: JohnRR] #244573
03/06/09 06:12 PM
03/06/09 06:12 PM
Santa Cruz, CA
1969cudaman Offline
1969cudaman  Offline
Santa Cruz, CA
^ A body M-codes listed E63 on the fender tags, yet we know that they were removed or never installed in place of the 440's. I'm sure that was the case with the 091 trans, which were replaced by 093.
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244574
03/06/09 06:14 PM
03/06/09 06:14 PM
Mass
charge70 Offline
charge70  Offline
Mass
I've read many articles regarding who did put the motor/trans into the M-code A bodies and the general consensus was that ma Mopar did it and not Hurst-Campbell like first reported.I would like to see copies of the paperwork you have on this.When I restored my 69 GTS M-code I installed the motor w/exhaust manifolds,trans,and k-frame from the bottom,it does fit.Now I don't have the build sheet for my car,but it is matching #'s and it has an 093 trans in it,with a sbd of 3-29. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: trans case number on 69 cuda m-code cars [Re: charge70] #244575
03/06/09 06:32 PM
03/06/09 06:32 PM
USA
big-block-dave Offline
USA
Guys, i have started a '69 M-code A-body 40th reunion at Carlisle in July. Watch carlisleevents.com soon for a sign up to bring your car!! Other ads maybe on this site, other mopar websites and 3 of the 4 mopars mags. Any M-code A-bodies can email me at mcodecuda@yahoo.com for more info and a invite/informational letter mailed to you!! I'm also in the process of reproducing the right side exhaust spacer that goes inbetween the manifold and head pipe! HELP SPREAD THE WORD!!!!! Dave
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: trans case number on 69 cuda m-code cars [Re: big-block-dave] #244576
03/06/09 07:04 PM
03/06/09 07:04 PM
Mass
charge70 Offline
charge70  Offline
Mass
Guys, i have started a '69 M-code A-body 40th reunion at Carlisle in July. Watch carlisleevents.com soon for a sign up to bring your car!! Other ads maybe on this site, other mopar websites and 3 of the 4 mopars mags. Any M-code A-bodies can email me at mcodecuda@yahoo.com for more info and a invite/informational letter mailed to you!! HELP SPREAD THE WORD!!!!! Dave
Dave count me in,I'll be there with my car.Who else? John.
Page 1 of 3 1 2 3
