Re: FiTech - Throttle Cable & Kickdown Linkage?
[Re: GoodysGotaCuda]
#2445584
02/03/18 12:41 PM
02/03/18 12:41 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Would the Edelbrock throttle lever bracket work for this They are made to adapt universal (most popular GM) to Mopar linkage. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2445596
02/03/18 01:01 PM
02/03/18 01:01 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
FiTech has the Holly style throttle arm. I just set one up using the Holley throttle adaptor PN# 20-7.
The only Carbs I care about are under the hood!
#2445635
02/03/18 02:24 PM
02/03/18 02:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just to point out, the Edelbrock adapter and the Holley adapter are not interchangeable.
#2445669
02/03/18 03:24 PM
02/03/18 03:24 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
My Father-in-Law is looking to install an FiTech setup on his '79 Li'l Red Express and I am wondering what challenges with throttle linkages we may run into.
If you have done this swap, were you able to retain the factory cable and kickdown linkage?
Or did you have to move to something like the Lokar setup for both? buddy of mine used the Edelbrock bracket. Aside for some alignment issues it works great. He will also have to make some adjustments to the throttle cable. He has a 79 Warlock with a bigblock
Abe Lincoln
#2447133
02/05/18 10:56 PM
02/05/18 10:56 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
I had to adjust the size of one of the holes in my Edelbrock bracket, but it works great. I have the factory throttle cable and kickdown linkage still in use.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
