Question on Jasper motors #2445208
02/02/18 02:43 PM
02/02/18 02:43 PM
Scranton, PA
Montclaire Offline OP
Scranton, PA
Hello, I picked up a 1989 TBI 360 that's a Jasper rebuild with only a handful of miles on it. I know Jasper is a pretty decent name, just wondering if there are any parts that I should replace before I run it - timing chain, oil pump, etc. I am guessing they use decent bearings and such but was curious if some of the accessories are lacking.
Re: Question on Jasper motors [Re: Montclaire] #2445227
02/02/18 03:33 PM
02/02/18 03:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Depends on handful of miles..i would run it first..before spending money on it..but I would do the water pump...
Re: Question on Jasper motors [Re: Montclaire] #2445228
02/02/18 03:34 PM
02/02/18 03:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'd bet the cam wasn't degreed so if you take it apart it's worth looking at. Cheap timing chain sets can be off a lot. Lining up the dots is how most do it, but you are making assumptions doing that.
Re: Question on Jasper motors [Re: Montclaire] #2445235
02/02/18 03:46 PM
02/02/18 03:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We installed quite a few at the shop years ago.All were decent motors.All seemed to run good and had no problems.They were all in daily drivers.I know of at least 2 that went well over 150K and were still going strong.Rocky
Chrysler Firepower
Re: Question on Jasper motors [Re: AARCONV] #2445263
02/02/18 05:13 PM
02/02/18 05:13 PM
Scranton, PA
Scranton, PA
Supposedly it has like 1500 on it. I pulled the valve cover and it's spotless. Why the water pump? I am going to dress it as a mid 70s version, so AFAIK the water pump and timing cover should be the same - I was going to leave it alone. Motor is non-AC and I am using it in an AC car though, so maybe the pump should be changed.
Re: Question on Jasper motors [Re: Montclaire] #2445337
02/02/18 07:36 PM
02/02/18 07:36 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What I would change would depend on how long it has been waiting to go into my ride. The longer the time frame since the last time it ran and now is, the more outside stuff I would change. Those items would pertain to things that go bad just sitting. Its easier to change stuff on an engine stand then it is in a car.
My experience with Jasper engines is, they seem to work well for daily drivers, but don't pull it apart expecting to find a blueprinted motor. Gene
Re: Question on Jasper motors [Re: Montclaire] #2445366
02/02/18 08:56 PM
02/02/18 08:56 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Our experiences with Jasper engines has always been good. Jasper uses OEM or better quality parts, not cheapy replacement parts from AutoZone. Timing chain and oil pump will be fine. The only accessory to be wary of is the alternator, and only if it's a Denso unit.
Re: Question on Jasper motors [Re: Jer] #2445436
02/03/18 12:28 AM
02/03/18 12:28 AM
Scranton, PA
Scranton, PA
Awesome, TY.
Re: Question on Jasper motors [Re: Jer] #2446125
02/04/18 12:00 PM
02/04/18 12:00 PM
moparx Offline
moparx  Offline
i have always had excellent luck with the denso alternator. what did you experience ?
beer
Re: Question on Jasper motors [Re: Montclaire] #2446308
02/04/18 04:42 PM
02/04/18 04:42 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
What would be a typical cost for a Gen III?
Core charge?
Round numbers would be fine.
Looks like they only quote prices thru installers.
Bill
Re: Question on Jasper motors [Re: Montclaire] #2446392
02/04/18 06:33 PM
02/04/18 06:33 PM
Scranton, PA
Scranton, PA
No idea, I stole this thing for like $200.
Re: Question on Jasper motors [Re: Montclaire] #2446803
02/05/18 01:11 PM
02/05/18 01:11 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yes that was quite a deal...
Re: Question on Jasper motors [Re: Montclaire] #2446834
02/05/18 01:57 PM
02/05/18 01:57 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
If you do NOT know when it was rebuilt, I would change the rear main seal. It's difficult to change that in the car, but easy while the engine is out.
Re: Question on Jasper motors [Re: Montclaire] #2446846
02/05/18 02:17 PM
02/05/18 02:17 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think there is a id number on the engine that their website can tell you whats in it--when it sold--they all have a warranty....
Re: Question on Jasper motors [Re: Montclaire] #2446859
02/05/18 02:44 PM
02/05/18 02:44 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I had one they epoxied an ID number to a freeze plug. I called Jasper and they told me dates and names, I called the shop that installed it and got the mileage and info from them.
Excellent engine, ran nice and smooth with greater power than the 70K mile engine it replaced
Re: Question on Jasper motors [Re: Montclaire] #2447215
02/06/18 12:54 AM
02/06/18 12:54 AM
Chicago
PurpleBeeper Offline
Chicago
I have been inside the Jasper plant several times (I used to sell them powder coating). It is a well run organization and everything I saw looked top notch. I "think" they may sell a few hopped-up motors now, but don't quote me on that. Jasper is known for good quality stock-rebuilt engines. My step-father (40 yr. mechanic) used to speak highly of them. That's all I know... I'd run it like it is, though like Neil mentioned, I don't think they degree camshafts, but I don't think that's an issue unless you're trying to get every ounce of power you can out of it.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Question on Jasper motors [Re: Montclaire] #2447337
02/06/18 12:43 PM
02/06/18 12:43 PM
Scranton, PA
Scranton, PA
I am leery of messing with the cam - the motor was strictly truck/van and in stock form was rated at 245/330 (nearly identical to the 1974 360 4bbl and slightly hotter than the 1973 340 4bbl). I have to imagine they installed it according to factory specs but it would probably be worth checking. There is not a ton of info out there on these motors so I don't know how forgiving that grind will be if I start tinkering with it...
Re: Question on Jasper motors [Re: QuickDodge] #2447352
02/06/18 01:11 PM
02/06/18 01:11 PM
Scranton, PA
Scranton, PA
Already in the plans, I have to swap the oil pan to a center sump anyway.
