Re: Question on Jasper motors
[Re: Montclaire]
#2445235
02/02/18 03:46 PM
02/02/18 03:46 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
We installed quite a few at the shop years ago.All were decent motors.All seemed to run good and had no problems.They were all in daily drivers.I know of at least 2 that went well over 150K and were still going strong.Rocky
Chrysler Firepower
[Re: AARCONV]
#2445263
02/02/18 05:13 PM
02/02/18 05:13 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Depends on handful of miles..i would run it first..before spending money on it..but I would do the water pump... Supposedly it has like 1500 on it. I pulled the valve cover and it's spotless. Why the water pump? I am going to dress it as a mid 70s version, so AFAIK the water pump and timing cover should be the same - I was going to leave it alone. Motor is non-AC and I am using it in an AC car though, so maybe the pump should be changed.
[Re: Jer]
#2445436
02/03/18 12:28 AM
02/03/18 12:28 AM
Montclaire
Scranton, PA
Our experiences with Jasper engines has always been good. Jasper uses OEM or better quality parts, not cheapy replacement parts from AutoZone. Timing chain and oil pump will be fine. The only accessory to be wary of is the alternator, and only if it's a Denso unit. Awesome, TY.
[Re: Montclaire]
#2446846
02/05/18 02:17 PM
02/05/18 02:17 PM
Posts: 2,042 colorado
savoy64
colorado
i think there is a id number on the engine that their website can tell you whats in it--when it sold--they all have a warranty....
[Re: Montclaire]
#2447215
02/06/18 12:54 AM
02/06/18 12:54 AM
Posts: 955 Chicago
PurpleBeeper
Chicago
I have been inside the Jasper plant several times (I used to sell them powder coating). It is a well run organization and everything I saw looked top notch. I "think" they may sell a few hopped-up motors now, but don't quote me on that. Jasper is known for good quality stock-rebuilt engines. My step-father (40 yr. mechanic) used to speak highly of them. That's all I know... I'd run it like it is, though like Neil mentioned, I don't think they degree camshafts, but I don't think that's an issue unless you're trying to get every ounce of power you can out of it.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: QuickDodge]
#2447352
02/06/18 01:11 PM
02/06/18 01:11 PM
Montclaire
Scranton, PA
If you do NOT know when it was rebuilt, I would change the rear main seal. It's difficult to change that in the car, but easy while the engine is out. Already in the plans, I have to swap the oil pan to a center sump anyway.
