Cooling system plumbed with AN fittings #2444416
02/01/18 01:28 AM
02/01/18 01:28 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Who has done it and could you share some pics with me please.
Working on plumbing the radiator to the block using -16 hose and fittings. I have a general idea how I want to do it but looking for other ideas as well.
THANKS!!!
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444424
02/01/18 01:48 AM
02/01/18 01:48 AM
AndyF Offline
AndyF  Offline
Several ways to do it. I make water manifold blocks that provide AN o-ring ports in and out of the block. That makes it easy to plumb a big block.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444425
02/01/18 01:56 AM
02/01/18 01:56 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I think your going to want to go bigger than -16 fittings. maybe -24 or -32, might not get enough flow through the -16 line
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444441
02/01/18 02:16 AM
02/01/18 02:16 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Most dragsters use the -16... shruggy
Re: Cooling system plumbed with AN fittings [Re: Dave Hall] #2444504
02/01/18 09:32 AM
02/01/18 09:32 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I don't remember what size mine are, but here area few pics. Using a Shogun water manifold. Runs cool, and cools down fast. Stage at 130* - 135*, and cross finish line at 145* - 150*. 160*- 165* at trailer in pits.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444505
02/01/18 09:35 AM
02/01/18 09:35 AM
Ringtown, Pa.
Ringtown, Pa.
I have been using this system since 2004. I wore out my 1st Shogun electric water pump last summer.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444514
02/01/18 10:19 AM
02/01/18 10:19 AM
PA
Harry's Taxi 2 Offline
PA
The shogun manifold uses #8 fittings. I used one, and line size was never a problem. (tried larger line size and higher pump capacity with different manifold configuration and no difference)
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444539
02/01/18 11:39 AM
02/01/18 11:39 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I have a standard cast aluminum water pump housing with a male -16 welded on the passenger side lower (inlet) my radiator has inlet and outlet on the passenger side (both -16) I have the bottom hose figured out using a 150 deg. sweep on the WP and a 90 deg. on the lower radiator
The upper I have a a 90 deg for the radiator and am working on what I need for the water outlet neck to get it around to the upper on the radiator. Wanted to use a T stat but I cant find a neck that has a -16 and accepts a T stat. I have a CVR swivel with a 90 that may work. Just looking at other options also.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444550
02/01/18 12:22 PM
02/01/18 12:22 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Been running-12 lines since 03, and would never run a race car without AN fittings again. Can make a 1/4 mile pass, and drive the mile back to the pit and never get over 170.
69 GTX 68 Road Runner
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444551
02/01/18 12:26 PM
02/01/18 12:26 PM
Wisconsin
Jet Doc Offline
Jet Doc  Offline
Wisconsin
check out autoplumb.com
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444552
02/01/18 12:27 PM
02/01/18 12:27 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would look at Meziere. They are sexy and they sell fittings to go AN in any size you like.
https://www.meziere.com/Products/Cooling-System-Products/Pumps-Electric/Mopar.aspx
I have used their reservoir style and their remote. Love them.
2011 Drag Pak Challenger
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444564
02/01/18 12:40 PM
02/01/18 12:40 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Another vote for Meziere. Good products, outstanding customer service and support.
I use -16 lines for cooling.
Re: Cooling system plumbed with AN fittings [Re: 340Cuda] #2444575
02/01/18 12:57 PM
02/01/18 12:57 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I haven't ran this setup yet, but its dual -12 an hoses with a Meziere radiator mounted pump and Meziere adapters on the motor plate..
Re: Cooling system plumbed with AN fittings [Re: Forest] #2444725
02/01/18 04:23 PM
02/01/18 04:23 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run -20 on my 70 Challenger for the upper & lower rad hoses due to mine is driven on the street. The -12 like everyone has pictured for just a drag car.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444730
02/01/18 04:40 PM
02/01/18 04:40 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
-16 street car no problems.
When the turbo cars got popular there seemed to be a lot of local ones stuffing the walls do to putting coolant down. I know of more than one that blew up a coolant hose when head gaskets let loose etc. Thats when I decided to go AN even though I am NA.
68 Barracuda Formula S 340
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444734
02/01/18 04:46 PM
02/01/18 04:46 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I looked into this though I just have an electric WP, no remote, no motor plate. Just a nicer way execute the system and the fittings can help with routing issues. Would be cool though if some of the rad companies offered the choice of threaded fittings installed for inlet and outlet hoses instead of having them welded on. Large angled/swivel fittings can add up for sure though. Nice job Forest!
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Cooling system plumbed with AN fittings [Re: cl440] #2444748
02/01/18 05:25 PM
02/01/18 05:25 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I use the Andy F water manifolds as shown above in Andy's post. 2- 12 an return lines off the top going to the top of the radiator, 2- 12an lines off the bottom going to the dual outlet pump and a 1 3/4" rubber hose feeding the remote.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2456187
02/23/18 03:32 PM
02/23/18 03:32 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Well this is how we ran the cooling lines. Had to use a couple 150 degree bends due to how close the radiator is to the engine. Should work fine.
We installed a bleeder valve in the top of the CVR water neck because this is the highest point in the system.
Thanks for all who posted photos and gave advice.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2456191
02/23/18 03:43 PM
02/23/18 03:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I took a picture of mine using -20 hose & fittings. The lower was not finished in this picture but is now. I like the look of the black hose & fittings even though it is a race/street car I was still going for that more of a Factory look.
Re: Cooling system plumbed with AN fittings [Re: cl440] #2456194
02/23/18 03:47 PM
02/23/18 03:47 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
We used -16 line and fittings. I do like the Black braid look. Wish our radiator had driver side in and out but it came with the car and is brand new so we made it work.
We went stainless braid on all the other lines. Stayed with Black fittings though.
