Re: Cooling system plumbed with AN fittings
[Re: Dave Hall]
#2444504
02/01/18 09:32 AM
02/01/18 09:32 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I don't remember what size mine are, but here area few pics. Using a Shogun water manifold. Runs cool, and cools down fast. Stage at 130* - 135*, and cross finish line at 145* - 150*. 160*- 165* at trailer in pits.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: cl440]
#2444505
02/01/18 09:35 AM
02/01/18 09:35 AM
Dartsport540
Ringtown, Pa.
I have been using this system since 2004. I wore out my 1st Shogun electric water pump last summer.
[Re: cl440]
#2444514
02/01/18 10:19 AM
02/01/18 10:19 AM
Posts: 287 PA
Harry's Taxi 2
PA
The shogun manifold uses #8 fittings. I used one, and line size was never a problem. (tried larger line size and higher pump capacity with different manifold configuration and no difference)
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: cl440]
#2444550
02/01/18 12:22 PM
02/01/18 12:22 PM
Posts: 10,038 MN
JERICOGTX
MN
Been running-12 lines since 03, and would never run a race car without AN fittings again. Can make a 1/4 mile pass, and drive the mile back to the pit and never get over 170.
69 GTX
68 Road Runner
[Re: cl440]
#2444564
02/01/18 12:40 PM
02/01/18 12:40 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Another vote for Meziere. Good products, outstanding customer service and support.
I use -16 lines for cooling.
[Re: Forest]
#2444725
02/01/18 04:23 PM
02/01/18 04:23 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I run -20 on my 70 Challenger for the upper & lower rad hoses due to mine is driven on the street. The -12 like everyone has pictured for just a drag car.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: cl440]
#2444730
02/01/18 04:40 PM
02/01/18 04:40 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
-16 street car no problems.
When the turbo cars got popular there seemed to be a lot of local ones stuffing the walls do to putting coolant down. I know of more than one that blew up a coolant hose when head gaskets let loose etc. Thats when I decided to go AN even though I am NA.
68 Barracuda Formula S 340
[Re: cl440]
#2444734
02/01/18 04:46 PM
02/01/18 04:46 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
I looked into this though I just have an electric WP, no remote, no motor plate. Just a nicer way execute the system and the fittings can help with routing issues. Would be cool though if some of the rad companies offered the choice of threaded fittings installed for inlet and outlet hoses instead of having them welded on. Large angled/swivel fittings can add up for sure though. Nice job Forest!
'71 Duster '72 Challenger '17 Ram 1500
[Re: cl440]
#2444748
02/01/18 05:25 PM
02/01/18 05:25 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I use the Andy F water manifolds as shown above in Andy's post. 2- 12 an return lines off the top going to the top of the radiator, 2- 12an lines off the bottom going to the dual outlet pump and a 1 3/4" rubber hose feeding the remote.
[Re: cl440]
#2456187
02/23/18 03:32 PM
02/23/18 03:32 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
Well this is how we ran the cooling lines. Had to use a couple 150 degree bends due to how close the radiator is to the engine. Should work fine. We installed a bleeder valve in the top of the CVR water neck because this is the highest point in the system.
Thanks for all who posted photos and gave advice.
[Re: cl440]
#2456191
02/23/18 03:43 PM
02/23/18 03:43 PM
6PKRTSE
Motor City
I took a picture of mine using -20 hose & fittings. The lower was not finished in this picture but is now. I like the look of the black hose & fittings even though it is a race/street car I was still going for that more of a Factory look.
