backspace and tire question for duster???? #244323
03/05/09 07:50 PM
03/05/09 07:50 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
My son got a good deal on some Welds, 15 X 8 with a 5.5 back space. Will this fit on a duster without minitubbing it and what is the biggest tire you can get in there with no minitub??
I have a set of 285 60 Mcrearys, wondering if anyone has done it. We sill end up minitubing it soon, and prob narrow the rear, i want to make it fit 10.5 W's eventually since they are so cheap as take offs on the Q8 cars
....BAD A$$ STREET CAR.....
Re: backspace and tire question for duster???? [Re: n20mstr] #244324
03/05/09 08:02 PM
03/05/09 08:02 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I have a 29.5 - 10.5 15 m/t slicks on a 10 inch rim 5 inch b/s
my dana 60 is 53 inchs long backing plate to backing plate
stock location springs , calterac setup NO minitubb
it depends on what rear you have !
DOC DIFF /CASSIE has a 1/2 off set shackel kit if you need too without minitubing the car
1.39 9.85 - 137 mph
Re: backspace and tire question for duster???? [Re: n20mstr] #244325
03/05/09 08:03 PM
03/05/09 08:03 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
4.5 backspace is what usually fits dusters.I think the 5.5 will hit the springs.If you mini tub and move the spings in they might work.If you do that a 15x12 wheel will work.
Re: backspace and tire question for duster???? [Re: 8secDart] #244326
03/05/09 08:11 PM
03/05/09 08:11 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Well right now we have an 8.8 out of an Explorer, im pretty sure it was 53"
Thanks for the replys
Re: backspace and tire question for duster???? [Re: n20mstr] #244327
03/05/09 10:34 PM
03/05/09 10:34 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
If it's stock width it should be about 59.5" it should work almost perfect in a duster with the 5.5" backspace wheels and the larger wheelwell that it has.
If you want the rear a bit narrower than a stock A body rear have the housing cut and run 2 pass side axles, it comes out to 56 7/8", a stock A body rear is 57 1/4"
Re: backspace and tire question for duster???? [Re: MoparJoe] #244328
03/05/09 10:52 PM
03/05/09 10:52 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
When I first started, I wasnt going to mini-tub my car and I fit the 275 hoosier drag radial on a 10" rim up in the well pretty nice, but that was the biggest tire that was going to tuck thats for sure
Re: backspace and tire question for duster???? [Re: n20mstr] #244329
03/05/09 10:59 PM
03/05/09 10:59 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
You won't need to cut the axle to fit a 10.5W. My old Duster had a stock width 8 3/4 with 10" rims and a 29x10.5W. It was mini tubbed with the springs moved in though.
Re: backspace and tire question for duster???? [Re: Dart1031] #244330
03/05/09 11:14 PM
03/05/09 11:14 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
do you know what was the backspacing on the 10 inch rim ADAM ?
1.39 9.85 - 137 mph
Re: backspace and tire question for duster???? [Re: MoparJoe] #244331
03/05/09 11:15 PM
03/05/09 11:15 PM
all of the A body 8 3/4 axles I have seen(1967 to 1971) and measured are the same length, stock or aftermarket race axles, what year axles are you talking about?
Re: backspace and tire question for duster???? [Re: Cab_Burge] #244332
03/05/09 11:26 PM
03/05/09 11:26 PM
8secDart Offline
8secDart  Offline
I was thinking the same thing,out of the couple hundred I built.An A-body housing is 52 and a hair.
Re: backspace and tire question for duster???? [Re: Cab_Burge] #244333
03/05/09 11:32 PM
03/05/09 11:32 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
He's putting an 8.8 from a ford explorer in it, the dr side axle is 2 7/8" longer than the pass side axle and the center section is offset, if you run 2 pass side axles it narrows the rear 2 7/8" and moves the center section back to the center of the rearend. On the width I'm going by flange to flange not housing width.
I did the same swap in my car and it's a pretty decent rear for the price, I would have liked to put an 8.75 under it but it's not in my budget.
Re: backspace and tire question for duster???? [Re: n20mstr] #244334
03/05/09 11:49 PM
03/05/09 11:49 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
on a side note, 275 drag radial in a 73 dart without minitub, is that doable? dr. diff 1/2" kit necessary? and cal-tracs will work with that wont it?
Re: backspace and tire question for duster???? [Re: j.mcconnell] #244335
03/06/09 12:26 AM
03/06/09 12:26 AM
8secDart Offline
8secDart  Offline
275 will fit with out any mods.
Re: backspace and tire question for duster???? [Re: Ari440] #244336
03/06/09 12:36 AM
03/06/09 12:36 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Hey Ari, I believe it was 5.5" BS.
Re: backspace and tire question for duster???? [Re: j.mcconnell] #244337
03/06/09 01:02 AM
03/06/09 01:02 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
My 1973 Dart Sport {same as duster} had a stock 8 3/4 from a dart swinger 340 car.
15x8 ralllies with 4.5 back sapce wraped in 275/60/15 BFG Drags
But I have Moser axles and 11x2.5 drums on the rear from a C Body and green bearings.
They made the offset of the axles for the wider brakes and drums. I have 5/8-3/4 inches from the side walls to springs
BFG Drags are a little wider than a regular 275
http://i234.photobucket.com/albums/ee87/fast340six/Dart%20Sport/glass3_17951075.jpg
http://i234.photobucket.com/albums/ee87/fast340six/Dart%20Sport/DSCN0048.jpg
http://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/Cruise3.jpg
Re: backspace and tire question for duster???? [Re: MoparJoe] #244338
03/06/09 07:21 PM
03/06/09 07:21 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
thanks a lot for that tip, The rear was a great deal, it was only 150.00 and it has 4.10 gears in it....
Re: backspace and tire question for duster???? [Re: n20mstr] #244339
03/07/09 12:08 AM
03/07/09 12:08 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Ours is a 275/60 on a 10 inch wheel with 5.5 backspace. We do have the offset shackles that move the springs in 3/4 inch.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: backspace and tire question for duster???? [Re: n20mstr] #244340
03/07/09 12:54 AM
03/07/09 12:54 AM
Utah
topbrent Offline
topbrent  Offline
Utah
We have a 255/70/15 which is 29.2 inches tall mounted on old mopar 15x7 Cop rim on my brothers 68 valiant.
A-body 8 3/4, Cal-tracs, Springs in stock location.
Clears OK. A little lip massaging wouldn't hurt, but it fits fine.
