backspace and tire question for duster????
#244323
03/05/09 07:50 PM
03/05/09 07:50 PM
Posts: 4,678 On the parachute mount
n20mstr
My son got a good deal on some Welds, 15 X 8 with a 5.5 back space. Will this fit on a duster without minitubbing it and what is the biggest tire you can get in there with no minitub?? I have a set of 285 60 Mcrearys, wondering if anyone has done it. We sill end up minitubing it soon, and prob narrow the rear, i want to make it fit 10.5 W's eventually since they are so cheap as take offs on the Q8 cars
....BAD A$$ STREET CAR.....
Re: backspace and tire question for duster????
[Re: n20mstr]
#244324
03/05/09 08:02 PM
03/05/09 08:02 PM
Posts: 5,618 long island NY
Ari440
long island NY
I have a 29.5 - 10.5 15 m/t slicks on a 10 inch rim 5 inch b/s my dana 60 is 53 inchs long backing plate to backing plate stock location springs , calterac setup NO minitubb it depends on what rear you have ! DOC DIFF /CASSIE has a 1/2 off set shackel kit if you need too without minitubing the car
1.39 9.85 - 137 mph
[Re: 8secDart]
#244326
03/05/09 08:11 PM
03/05/09 08:11 PM
n20mstr
Well right now we have an 8.8 out of an Explorer, im pretty sure it was 53" Thanks for the replys
[Re: Cab_Burge]
#244333
03/05/09 11:32 PM
03/05/09 11:32 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
and run 2 pass side axles,
all of the A body 8 3/4 axles I have seen(1967 to 1971) and measured are the same length, stock or aftermarket race axles, what year axles are you talking about?
He's putting an 8.8 from a ford explorer in it, the dr side axle is 2 7/8" longer than the pass side axle and the center section is offset, if you run 2 pass side axles it narrows the rear 2 7/8" and moves the center section back to the center of the rearend. On the width I'm going by flange to flange not housing width.
I did the same swap in my car and it's a pretty decent rear for the price, I would have liked to put an 8.75 under it but it's not in my budget.
[Re: Ari440]
#244336
03/06/09 12:36 AM
03/06/09 12:36 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
You won't need to cut the axle to fit a 10.5W. My old Duster had a stock width 8 3/4 with 10" rims and a 29x10.5W. It was mini tubbed with the springs moved in though.
do you know what was the backspacing on the 10 inch rim ADAM ?
Hey Ari, I believe it was 5.5" BS.
[Re: MoparJoe]
#244338
03/06/09 07:21 PM
03/06/09 07:21 PM
n20mstr
thanks a lot for that tip, The rear was a great deal, it was only 150.00 and it has 4.10 gears in it....
[Re: n20mstr]
#244339
03/07/09 12:08 AM
03/07/09 12:08 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Ours is a 275/60 on a 10 inch wheel with 5.5 backspace. We do have the offset shackles that move the springs in 3/4 inch.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
