W2 head to LA header adapters #2441908
01/28/18 01:28 AM
01/28/18 01:28 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I have read some post on this subject but don't really understand what the adapters do. I have the duel bolt pattern heads. Could someone explain?
I would like to run LA headers on a W2 head with the dual bolt pattern.
Re: W2 head to LA header adapters [Re: mopfried] #2442162
01/28/18 01:04 PM
01/28/18 01:04 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Some headers have a flange that does not fit W2 or stock heads. There is a plate that bolts on the heads to mate the header to the head. One for W2 one for standard.
For your application you might have to fabricate a plate as long as the headers would still fit, spaced out from the heads somewhat.
Re: W2 head to LA header adapters [Re: 340Cuda] #2442171
01/28/18 01:15 PM
01/28/18 01:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
You better lay a gasket on the head to so if what you want to do is possible. That may be one heck of a restriction. I ran it the other way on my Duster
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W2 head to LA header adapters [Re: mopfried] #2442176
01/28/18 01:19 PM
01/28/18 01:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a set of those, will post a pic later. The problems you need to be aware of are the header tube clearances down stream of the flanges because they will be located slightly different with the added flanges. Starter, steering box and shaft, clutch Z-bar, etc. can be a problem. 4 speed cars especially. DAMHIK!
Re: W2 head to LA header adapters [Re: ScottSmith_Harms] #2442377
01/28/18 06:55 PM
01/28/18 06:55 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Thanks Scott, I would like to see them.
Re: W2 head to LA header adapters [Re: mopfried] #2443208
01/30/18 02:42 AM
01/30/18 02:42 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
btt
Re: W2 head to LA header adapters [Re: mopfried] #2443973
01/31/18 12:03 PM
01/31/18 12:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Adapters
Re: W2 head to LA header adapters [Re: ScottSmith_Harms] #2445627
02/03/18 02:15 PM
02/03/18 02:15 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Thanks Scott. I dont see how that would adapt LA headers to a duel bolt pattern W-@ head though. I guess im missing something.
Re: W2 head to LA header adapters [Re: mopfried] #2445919
02/03/18 10:37 PM
02/03/18 10:37 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
If you have the dual bolt pattern on your exhaust port then the LA headers bolt right to your head, and you dont need the adapter plates Scott showed
This thread helps show the port mismatch:
https://board.moparts.org/ubbthreads/ubbt...tml#Post2423499
The adapter Scott posted (same pattern as the adapter in my post) mounts a non stock race header pattern shown here
Re: W2 head to LA header adapters [Re: UCUDANT] #2446395
02/04/18 06:40 PM
02/04/18 06:40 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Oh, I see. I thought somehow the adapters helped with the port mismatch not the bolt pattern. I see. I See.. Thanks.
