which alum intake 2 use for a 318 for shaker setup?
#2442562
01/29/18 12:09 AM
01/29/18 12:09 AM
Posts: 2,943 GA
roadrunninMark
GA
I am looking at getting the correct height intake for my 318 to use with a 4 barrel to get the correct height for a single 4 barrel shaker set up. I have a thermoquad I was going to use, so probably need a spread bore. I want to go with a dual plane as well, for street use and an alum for weight reduction. I am thinking of the weiand action plus would be the best (I see this manifold is higher in the back, would that be a problem?)? What are you guys using that have shakers? Did you have to use any spacers?
Re: which alum intake 2 use for a 318 for shaker setup?
[Re: roadrunninMark]
#2442857
01/29/18 01:52 PM
01/29/18 01:52 PM
RapidRobert
I have no "shaker" experience but a street dominator is a spreadbore single plane that works "so so" & it is a very low profile & spacers could be added. here's a BTT for ya.
#2443346
01/30/18 12:51 PM
01/30/18 12:51 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Is it even legal to run a Shaker hood on a 318?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#2443492
01/30/18 04:12 PM
01/30/18 04:12 PM
Posts: 1,945 Olympia, Washington
tallzag
Olympia, Washington
Getting the height right can be tricky. We sell carb spacers if it is too low. Would think an intake like the LD340 would get it to the right height.
Rocket Restorations
[Re: tallzag]
#2443619
01/30/18 07:53 PM
01/30/18 07:53 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Getting the height right can be tricky. We sell carb spacers if it is too low. Would think an intake like the LD340 would get it to the right height. LD340 would cause a port mismatch - better off with an LD4B.
