which alum intake 2 use for a 318 for shaker setup? #2442562
01/29/18 12:09 AM
01/29/18 12:09 AM
GA
roadrunninMark Offline OP
GA
I am looking at getting the correct height intake for my 318 to use with a 4 barrel to get the correct height for a single 4 barrel shaker set up. I have a thermoquad I was going to use, so probably need a spread bore. I want to go with a dual plane as well, for street use and an alum for weight reduction. I am thinking of the weiand action plus would be the best (I see this manifold is higher in the back, would that be a problem?)?
What are you guys using that have shakers? Did you have to use any spacers?
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2442857
01/29/18 01:52 PM
01/29/18 01:52 PM
I have no "shaker" experience but a street dominator is a spreadbore single plane that works "so so" & it is a very low profile & spacers could be added. here's a BTT for ya.
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443136
01/30/18 12:01 AM
01/30/18 12:01 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If you want to use a thermoquad and not shorten your baseplate find an old LD340. Performer rpm will fit with baseplate mods.
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443189
01/30/18 01:46 AM
01/30/18 01:46 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I run an older torker
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443346
01/30/18 12:51 PM
01/30/18 12:51 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Is it even legal to run a Shaker hood on a 318?
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443363
01/30/18 01:20 PM
01/30/18 01:20 PM
GA
GA
Sure, when the 318 has more "cajones" than a 340 smile
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443474
01/30/18 03:44 PM
01/30/18 03:44 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
Getting the height right can be tricky. We sell carb spacers if it is too low.
Rocket Restorations
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443492
01/30/18 04:12 PM
01/30/18 04:12 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
Getting the height right can be tricky. We sell carb spacers if it is too low. Would think an intake like the LD340 would get it to the right height.
Rocket Restorations
Re: which alum intake 2 use for a 318 for shaker setup? [Re: tallzag] #2443619
01/30/18 07:53 PM
01/30/18 07:53 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
LD340 would cause a port mismatch - better off with an LD4B.
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443827
01/31/18 01:37 AM
01/31/18 01:37 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
LD4B and LD340 won't work with a thermoquad unless you carve them up.
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443847
01/31/18 02:05 AM
01/31/18 02:05 AM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
True - but I put one on a magnum motor once - that took some work.
Rocket Restorations
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2443854
01/31/18 02:14 AM
01/31/18 02:14 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Edelbrock 2176 for 318 port size, ld340 carved up for thermoquad. I would forget the theroquad and use an ld340.
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2444032
01/31/18 01:48 PM
01/31/18 01:48 PM
GA
GA
I will be getting the ProMax alum heads, not using stock heads. Will that take care of any port mismatch?
So use the ld340 and which carb and size to go with? I am figuring around 375 hp.
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2445495
02/03/18 03:56 AM
02/03/18 03:56 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Yes on port match, a performer rpm would also work and fit at that power level,and be cheaper not the airgap performer.
Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark] #2445496
02/03/18 03:59 AM
02/03/18 03:59 AM
P
Porter67 Offline
Porter67  Offline
P
When I had the 440 out of mine I ran a older edelbrock 2-4 intake and a year one fiberglass hemi baseplate and it fit like oem.
