#2442562 - 01/28/18 09:09 PM which alum intake 2 use for a 318 for shaker setup?
roadrunninMark Offline
Loc: GA
I am looking at getting the correct height intake for my 318 to use with a 4 barrel to get the correct height for a single 4 barrel shaker set up. I have a thermoquad I was going to use, so probably need a spread bore. I want to go with a dual plane as well, for street use and an alum for weight reduction. I am thinking of the weiand action plus would be the best (I see this manifold is higher in the back, would that be a problem?)?
What are you guys using that have shakers? Did you have to use any spacers?
Edited by roadrunninMark (01/28/18 09:30 PM)
#2442857 - 01/29/18 10:52 AM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
RapidRobert Online   content
Loc: Lincoln Nebraska
I have no "shaker" experience but a street dominator is a spreadbore single plane that works "so so" & it is a very low profile & spacers could be added. here's a BTT for ya.
#2443136 - 01/29/18 09:01 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
4406bbl Offline
Loc: Nebraska
If you want to use a thermoquad and not shorten your baseplate find an old LD340. Performer rpm will fit with baseplate mods.
#2443189 - 01/29/18 10:46 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
AARCONV Offline
Loc: NEW JERSEY
I run an older torker
#2443346 - 01/30/18 09:51 AM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
jbc426 Offline
Loc: West Coast, USA
Is it even legal to run a Shaker hood on a 318?
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
#2443363 - 01/30/18 10:20 AM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
Loc: GA
Sure, when the 318 has more "cajones" than a 340 smile
#2443474 - 01/30/18 12:44 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
tallzag Offline
Loc: Olympia, Washington
Getting the height right can be tricky. We sell carb spacers if it is too low.
Rocket Restorations
#2443492 - 01/30/18 01:12 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
tallzag Offline
Getting the height right can be tricky. We sell carb spacers if it is too low. Would think an intake like the LD340 would get it to the right height.
Rocket Restorations
#2443619 - 01/30/18 04:53 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: tallzag]
Montclaire Offline
Loc: Scranton, PA
LD340 would cause a port mismatch - better off with an LD4B.
1973 Dodge Charger from "Burn Notice"
#2443827 - 01/30/18 10:37 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
forphorty Offline
Loc: oklahoma
LD4B and LD340 won't work with a thermoquad unless you carve them up.
#2443847 - 01/30/18 11:05 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
tallzag Offline
True - but I put one on a magnum motor once - that took some work.
Rocket Restorations
#2443854 - 01/30/18 11:14 PM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
4406bbl Offline
Loc: Nebraska
Edelbrock 2176 for 318 port size, ld340 carved up for thermoquad. I would forget the theroquad and use an ld340.
#2444032 - 01/31/18 10:48 AM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
Loc: GA
I will be getting the ProMax alum heads, not using stock heads. Will that take care of any port mismatch?
So use the ld340 and which carb and size to go with? I am figuring around 375 hp.
#2445495 - 02/03/18 12:56 AM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
4406bbl Offline
Loc: Nebraska
Yes on port match, a performer rpm would also work and fit at that power level,and be cheaper not the airgap performer.
#2445496 - 02/03/18 12:59 AM Re: which alum intake 2 use for a 318 for shaker setup? [Re: roadrunninMark]
EV2Bird Offline
No more politics
Loc: Kansas Roads Between 0 and 140...
When I had the 440 out of mine I ran a older edelbrock 2-4 intake and a year one fiberglass hemi baseplate and it fit like oem.
25,702 Registered Members
196,789 Topics
57 Belvedere - a few fixes
by mopardwh
01/20/19 11:46 PM
Anyone else watching the lunar eclipse tonight?
by Alaskan_TA
01/20/19 10:56 PM
Any Ford Techs on here?
by oldjonny
01/20/19 10:06 PM
Hot Rod Power Tour 2019 (MoPowered Tour)
by Devil
01/20/19 09:53 PM
