4sp cross application? #244241
03/05/09 05:26 PM
03/05/09 05:26 PM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
Will a 833 transmission and shifter from a a body work in a 65 B body? Or is there something different? I dont know the year the a body was.
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: 4sp cross application? [Re: 65 NSS 500] #244242
03/05/09 05:36 PM
03/05/09 05:36 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
No, 64-5 B is a different animal from the A body. 66-9 B trans is the best fit and also uses the slip yoke.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 4sp cross application? [Re: 65 NSS 500] #244243
03/05/09 06:26 PM
03/05/09 06:26 PM
The B body 4 speeds have a longer tailshaft than the A bodys do, if your a fabricator you can make anything fit and work. The A body shifter is mounted in a different location also so it would probally be better to get a B body tran and use it like already said. The 1965 B body 4 speed trans had the ball and trunion U joint and yoke like the 1963 and 1964 cars had, the 1965 automatic trans in the B bodys had slip yokes with conventional U joints from then on. The 1966 and later NP833 had slip yokes from then on also but the 1964 and 1965 NP833 are ball and trunion yoke and U joints drive shafts IHTHs
