Re: Now I REALLY need an alternator..............
[Re: Thumperdart]
#2440622
01/25/18 04:46 PM
01/25/18 04:46 PM
Posts: 2,923 A shed in England
Tig
A shed in England
Power Master 105 amp, modified to work with a DMI low mount bracket. Runs a grid, 2 x O2 sensors and a little data logging, Magnafuel 500, twin electric pusher fans, Moroso 35gph(?) electric w/p. All the lights barring the headlights are LED's. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Thumperdart]
#2440628
01/25/18 04:59 PM
01/25/18 04:59 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I have a gm 😲😲, alt, think it is a cs105. Allegedly works better than a true single wire unit. Seems to be fine with dual fans, elec pump, lm2, ignition box, electric wp, etc. When fans kick on at night, headlights will dim just for a split second, nothing major.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Forest]
#2440961
01/26/18 01:18 PM
01/26/18 01:18 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I am running all of the same electronics as listed above by most & also using a Powermaster 105 Amp GM one wire with a custom low mount. Most of everything mounts to my front plate.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Thumperdart]
#2440969
01/26/18 01:33 PM
01/26/18 01:33 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I run a GM CS130 off of a 91 Olds Cutlass V6. It is 105 amp and has been rock solid for years and has lots of miles on it. I do not have it set up for one wire, I wired it with a charge light and a voltage sense wire from a diagram on the Mad electrical site.
68 Barracuda Formula S 340
[Re: Thumperdart]
#2440979
01/26/18 01:52 PM
01/26/18 01:52 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I put those $80 chrome cs130 1 wire alts from ebay on everything
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: crackedback]
#2441084
01/26/18 05:13 PM
01/26/18 05:13 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Look for one off a 90 amp off a Toyota. I think a 2000ish 4 cyl camry might do the trick. Even if it has a serpentine, you have a v groove pulley to change it over.
Watch out for clearance at rear of alternator as they tend to get longer with more amps. Found one but because it had a weird connector I passed and got another 60 amp like the one I had..........clocked different then the other one and 5 hours later to make brackets and rewire, this b%^&h better work or I'll get the GM unit.............
[Re: Tig]
#2441129
01/26/18 06:56 PM
01/26/18 06:56 PM
Thumperdart
State of confusion
Power Master 105 amp, modified to work with a DMI low mount bracket. Runs a grid, 2 x O2 sensors and a little data logging, Magnafuel 500, twin electric pusher fans, Moroso 35gph(?) electric w/p. All the lights barring the headlights are LED's. HTH's This alt keeps up fine now..............
[Re: Thumperdart]
#2441324
01/27/18 01:41 AM
01/27/18 01:41 AM
Posts: 3,009 Covington Georgia
RV2
Covington Georgia
I Use the alternators off of late 80's/ early 90's ram trucks. Have one on my 557" Hemi and one on my 383.
[Re: Thumperdart]
#2442293
01/28/18 04:21 PM
01/28/18 04:21 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
Dom I used a 120 amp Denso on my big block 73 Dart. It’s for a 1990 5.2 Dodge van
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
