Now I REALLY need an alternator.............. #2440587
01/25/18 03:54 PM
01/25/18 03:54 PM
State of confusion
Thumperdart Offline OP
State of confusion
This old dog is finally giving up the ghost so I need a parts store not Jegs, Summit stuff so I can walk in and exchange it. Mine is a 60 amp Denso and was thinking a one wire GM may be the key so what part # are you guys running in at least a 90 amp range............thankxxx...... beer
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2440622
01/25/18 04:46 PM
01/25/18 04:46 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Power Master 105 amp, modified to work with a DMI low mount bracket. Runs a grid, 2 x O2 sensors and a little data logging, Magnafuel 500, twin electric pusher fans, Moroso 35gph(?) electric w/p. All the lights barring the headlights are LED's.
HTH's
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2440628
01/25/18 04:59 PM
01/25/18 04:59 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I have a gm 😲😲, alt, think it is a cs105. Allegedly works better than a true single wire unit. Seems to be fine with dual fans, elec pump, lm2, ignition box, electric wp, etc. When fans kick on at night, headlights will dim just for a split second, nothing major.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Now I REALLY need an alternator.............. [Re: Von] #2440654
01/25/18 05:52 PM
01/25/18 05:52 PM
State of confusion
State of confusion
Thankxxx guys and I think I am going to try the Denso 80 amp here in a bit then go from there if I need more............ thumbs
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2440664
01/25/18 06:17 PM
01/25/18 06:17 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
http://arengineering.com/products/denso-60-amp-kit-big-block/
I've had this Toyota 4Runner Denso alternator on my street driven dart for 14-15 years.
Re: Now I REALLY need an alternator.............. [Re: Forest] #2440961
01/26/18 01:18 PM
01/26/18 01:18 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I am running all of the same electronics as listed above by most & also using a Powermaster 105 Amp GM one wire with a custom low mount. Most of everything mounts to my front plate.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2440969
01/26/18 01:33 PM
01/26/18 01:33 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run a GM CS130 off of a 91 Olds Cutlass V6. It is 105 amp and has been rock solid for years and has lots of miles on it. I do not have it set up for one wire, I wired it with a charge light and a voltage sense wire from a diagram on the Mad electrical site.
68 Barracuda Formula S 340
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2440979
01/26/18 01:52 PM
01/26/18 01:52 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I put those $80 chrome cs130 1 wire alts from ebay on everything
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2441014
01/26/18 03:02 PM
01/26/18 03:02 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also have a GM 1 wire 100 amp.They didn't have 1 wire MOPAR units yet.One of these days I will install one of those light nip units! smoke
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2441082
01/26/18 05:10 PM
01/26/18 05:10 PM
CA
crackedback Offline
crackedback  Offline
CA
Look for one off a 90 amp off a Toyota. I think a 2000ish 4 cyl camry might do the trick. Even if it has a serpentine, you have a v groove pulley to change it over.
Watch out for clearance at rear of alternator as they tend to get longer with more amps.
Re: Now I REALLY need an alternator.............. [Re: crackedback] #2441084
01/26/18 05:13 PM
01/26/18 05:13 PM
State of confusion
State of confusion
Found one but because it had a weird connector I passed and got another 60 amp like the one I had..........clocked different then the other one and 5 hours later to make brackets and rewire, this b%^&h better work or I'll get the GM unit............. realcrazy
Re: Now I REALLY need an alternator.............. [Re: Tig] #2441129
01/26/18 06:56 PM
01/26/18 06:56 PM
State of confusion
State of confusion
HTH's
This alt keeps up fine now.............. beer
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2441262
01/26/18 11:34 PM
01/26/18 11:34 PM
fullmetaljacket Offline
1 wire GM 140 here. My Boyz despise of me for having a Bowtie part on my engine, but at least I'm not tying up traffic while stuck on the side of the road.
Lighter than the old Chrysler units as well.
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2441282
01/27/18 12:02 AM
01/27/18 12:02 AM
hemi-itis Offline
hemi-itis  Offline
I bettling the Nip is several lbs lighter scope
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2441324
01/27/18 01:41 AM
01/27/18 01:41 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I Use the alternators off of late 80's/ early 90's ram trucks.
Have one on my 557" Hemi and one on my 383.
Re: Now I REALLY need an alternator.............. [Re: hemi-itis] #2441398
01/27/18 05:56 AM
01/27/18 05:56 AM
State of confusion
State of confusion
Lighter and super happy with how it's working........... thumbs
Re: Now I REALLY need an alternator.............. [Re: Forest] #2441438
01/27/18 12:42 PM
01/27/18 12:42 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
yep the only way to go
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2441535
01/27/18 03:28 PM
01/27/18 03:28 PM
Boise
Moparteacher Offline
Boise
I have a 60 amp Nippondenso off a 4-Runner. It puts out approximately 62 amps at full-field. With the MSD 6A, Two factory puller fans from an Intrepid, a single electric fuel pump, and a CSR reverse flow waterpump the draw is right at 60 amps at 70 degrees F., and I haven't turned the lights on yet.
If you're running a mechanical waterpump and fan then 60 amps should barely fit the bill. You really don't want to run the alternator at full-field, 80% is pushing it for heat considerations. Any more and you should step up.
Mine is mounted on an older DMI low mount with a few modifications.
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2441853
01/28/18 12:33 AM
01/28/18 12:33 AM
Parts unknown
590 Challenger Offline
Parts unknown
Denso is a much better alternator, It uses much larger bearings and will last much much longer than the CS130, delco, powermaster or who ever's. Delco on their later desighns copied a lot off the denso to make theirs better, double internal fans, smaller slip rings causing less wear. Denso is just all around a superior alternator
Re: Now I REALLY need an alternator.............. [Re: Thumperdart] #2442293
01/28/18 04:21 PM
01/28/18 04:21 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Dom I used a 120 amp Denso on my big block 73 Dart. It’s for a 1990 5.2 Dodge van
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
