Big block solid roller lifter advice #2438458
01/21/18 03:54 PM
01/21/18 03:54 PM
San Diego
formula S Offline OP
San Diego
I'm interested in a roller lifter for a decent price that will handle about .700 lift without uncovering the oil hole, any suggestions?
Re: Big block solid roller lifter advice [Re: formula S] #2438469
01/21/18 04:31 PM
01/21/18 04:31 PM
AndyF Offline
AndyF  Offline
I use the Comp 861-16 lifter which is the AMC version. You have to order the Mopar link bars. The 861 lifters are a good value and they provide needle bearing oiling as well as pushrod oiling if you want.
There are other brands available such as Morel. Crane roller lifters work really well but are more expensive.
Re: Big block solid roller lifter advice [Re: formula S] #2438475
01/21/18 04:37 PM
01/21/18 04:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have the Comp 848 which has been upgraded to the 861 Andy speaks of.I just had my 848s rebuilt for the second time in 10 years.One needed replacement and they gave me an 861.The tie bar tab is in a lower location but still worked with the tie bar and did not hit the lifter boss on the Mega block. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Big block solid roller lifter advice [Re: formula S] #2438554
01/21/18 07:33 PM
01/21/18 07:33 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Crane 66550-16
Can't speak for the others suggested BUT you need a lifter with the wheel shrouded so as not to expose the oil passage. This lifter does the trick.
In hindsight I would have bought a set with bushings instead of roller bearings. But it baffles the hell out of me why a lifter with a bushing in the roller should cost more than one with roller bearings !!
Re: Big block solid roller lifter advice [Re: formula S] #2438639
01/21/18 09:24 PM
01/21/18 09:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Crower solid body roller lifters.
Re: Big block solid roller lifter advice [Re: AndyF] #2438678
01/21/18 10:04 PM
01/21/18 10:04 PM
San Diego
San Diego
Are the morel lifters configured the same way so there's no need to Bush the lifter bores to control the oil
Re: Big block solid roller lifter advice [Re: formula S] #2439130
01/22/18 06:25 PM
01/22/18 06:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Many years on the street w/a .680-.660 276-281 @ .050 Isky solid roller and solid body lifters..........one rebuild in many years/miles....... thumbs
Re: Big block solid roller lifter advice [Re: formula S] #2439133
01/22/18 06:33 PM
01/22/18 06:33 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Remember: cam base circle diameter affects lifter position.
Boffin Emeritus
Re: Big block solid roller lifter advice [Re: formula S] #2439373
01/23/18 02:48 AM
01/23/18 02:48 AM
hemi-itis Offline
hemi-itis  Offline
That would become a mock up so not to muckup work
Re: Big block solid roller lifter advice [Re: formula S] #2439396
01/23/18 03:38 AM
01/23/18 03:38 AM
AndyF Offline
AndyF  Offline
I just verified on my 470 engine that the oil gallery is not uncovered. I'm using unbushed lifter bores, Comp 861 (AMC) roller lifters and I have about 0.800 lift at the valve with 1.65 rocker arms.
When you get close to the limit you need to double check everything. We just put the short block together and then spin the oil pump by hand and watch how the oiling works. Make sure you rotate the engine over a few times so you can see how each lifter oils at max lift.
Re: Big block solid roller lifter advice [Re: AndyF] #2439403
01/23/18 03:57 AM
01/23/18 03:57 AM
I'm having to have a 400 block lifter bores bushed right now due to using Comp Cams AMC lifters for push rod oiling for the Jesel rocker arms shruggy I had the motor assembled and had 20 Lbs. oil pressure using my old 1/2 inch Craftsman drill motor to prime it with which I normally get 75 to 80 Lbs. on all my other motors with all the other solid roller lifters I've used before these work
I tried a set of Crane Ultra lifters with the side cut outs and got zero oil pressure puke
I put in a used set of the early Engles solid body roller lifters and got 75 Lbs. boogie
Live and learn shruggy IHTHs thumbs
Re: Big block solid roller lifter advice [Re: formula S] #2439480
01/23/18 12:20 PM
01/23/18 12:20 PM
crabman173
crabman173
Comp 829-16 solid body are the old tried and true why in the H%&* the others don't do a solid body is beyond me
Keep pressures reasonable --no 800 open and they will do fine with ZERO oil pressure issues
Re: Big block solid roller lifter advice [Re: formula S] #2439539
01/23/18 02:09 PM
01/23/18 02:09 PM
hemi-itis Offline
hemi-itis  Offline
I had bad luck with the 829 and spring pressure over 700# over the nose....
Re: Big block solid roller lifter advice [Re: formula S] #2440176
01/24/18 06:28 PM
01/24/18 06:28 PM
San Diego
San Diego
We are using a bullet Cam and bullet sells Morel lifters, but they look like from the picture that they are not a solid body lifter
The next question is what is the wheel diameter on the different lifters that all of you have listed
Bullet cams recommended a .810 or .820 wheel
Re: Big block solid roller lifter advice [Re: hemi-itis] #2440195
01/24/18 07:37 PM
01/24/18 07:37 PM
crabman173
crabman173
Yea I never go that high --usually 700 max and keep an eye on them at LEAST once a season pull and check
This entire issue would be better if we could get the solid body with Morel quality and or bushed
Drag racers think bigger is better you usually do not need that high of pressure if a good lobe is selected--as engine builders we always ask the cam maker NOT for the latest computer grind--that can be hell on parts but we ask for a smooth proven lobe that is EASY on parts and requires less pressure to work
Crazy hot latest thing lobes usually require very high pressure to TRY and control them and for what?? a few more claimed HP?? we are usually bracket racing anyway so what the heck Crazy to not get lobes that are easy on stuff
829's are not the best-by far-- the solid body is the claim to fame zero oil issues- but....they are pretty darn good when used with a good lobe and reasonable pressures and ...are replaced every season--sell old ones at swap and keep rolling
BTW if you send in to Comp for rebuild they always say several were no good now you have mix of new and rebuilt at price of new set so that is a bust well documented on here and a lame way to go--sell the old ones and move on
OR.....Use Morels, Isky etc with direct oil pressure and maybe bushings THEN still get a smooth lobe and explain you do not want reduced base circle or massive lobe lift that you are fighting that band being exposed--work with pros that knows kinda deal Todd Marsh, Comp, Andy, and others that are just as good--there are many on here and then.....replace every season any darn way to keep a lifter from killing the entire engine
Spring pressure to excess to control crazy lobes ( or just for the heck of it) KILLS lifters --as well as dreaded valve float from un-skilled driver--too many RPM in water--etc etc
In our circle track builds we had drivers that we could run VERY close piston to valve never an issue and we had drivers we had to jack it with LOTS more PTV because they could make it kiss anyway no matter what--in other words they had no idea how to drive a race car and care for equipment
Re: Big block solid roller lifter advice [Re: formula S] #2440226
01/24/18 09:08 PM
01/24/18 09:08 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
In an earlier post I mentioned the shrouding around the rollers. This photo of a set of small block roller lifters illustrates my point. Look at the difference in space above the rollers on the lifters I've circled.
A similar lifter in a RB with a .600 lift cam exposed the oil galley to the point the oil poured out. You want a set of lifters with the wheel shrouded (they generally only do it on the galley side of the lifter)
Re: Big block solid roller lifter advice [Re: AndyF] #2440243
01/24/18 09:40 PM
01/24/18 09:40 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Good advice Andy.
RIP Monte Smith
Re: Big block solid roller lifter advice [Re: formula S] #2440350
01/25/18 01:49 AM
01/25/18 01:49 AM
SoCal
Brian Hafliger Offline
SoCal
I called you back...
Brian Hafliger
