Factory sunroof question #2439344
01/23/18 01:50 AM
01/23/18 01:50 AM
Northern California
FuryRoad Offline OP
FuryRoad  Offline OP
Northern California
I have access to a 73 imperial with a factory sliding sunroof. The car is to far gone to do anything with. My question is it the same sunroof as a A,B,or E or even another C body or is it dedicated to the 73 imperial. In other words is the sunroof a drop in universal unit or do they all have different roof lines.
Re: Factory sunroof question [Re: FuryRoad] #2439348
01/23/18 01:56 AM
01/23/18 01:56 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The C-bodies have a wider panel & under pan for sure.
Not sure if the Imperials use the same parts as a C, but a parts book would clear that up.
Parts are not easy to find for those that need them though.
Re: Factory sunroof question [Re: Alaskan_TA] #2439401
01/23/18 03:49 AM
01/23/18 03:49 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Did Chrysler even supply the parts for these? I thought all the roof cutting was done by outside sources?
Re: Factory sunroof question [Re: FuryRoad] #2440031
01/24/18 02:36 PM
01/24/18 02:36 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
All the sunroofs were supplied by American Sunroof Corporation - ASC (I think that was the name) . . . was started by a German fellow who supplied sunroofs to BMW, Audi, MB, etc. . . ASC still in business to this day !!
My 74 Duster360 was factory sunroof car. In the A bodies anyway, not sure on B E and C, the sunroof and mechanism was bolted up to the roof of the car.
https://americansunroof.com/
Cheers
Mark
Re: Factory sunroof question [Re: FuryRoad] #2440129
01/24/18 05:06 PM
01/24/18 05:06 PM
Northern California
FuryRoad Offline OP
FuryRoad  Offline OP
Northern California
What I'm wondering if I pick up this 73 imperial could I remove the sunroof parts from the imperial and put it in a b or e body? Has anybody here ever done that? I will register the imp with asc registry even if its junk.
Re: Factory sunroof question [Re: FuryRoad] #2440144
01/24/18 05:42 PM
01/24/18 05:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
B will fit E, but Cs & Imps are too big.
