727 Adjuster screw leaking - O-ring seal fix? #2438107
01/20/18 08:43 PM
01/20/18 08:43 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Is there a o-ring under thats under the adjuster screw nut? Cleaned up/power washed an old 727 with 60k mile on it & going to stick it in a SWB D100. It's just been sitting in the shop since I washed it & it's leaking from that adjuster screw. Any ideas?
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2438115
01/20/18 09:13 PM
01/20/18 09:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
No O ring.
I just use pipe thread sealant. The one in the tube. not the tape.
Aka - white thread lock
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2438124
01/20/18 09:32 PM
01/20/18 09:32 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Solution 40 anaerobic sealant.
Angry white pureblood male
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2438252
01/21/18 02:15 AM
01/21/18 02:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use Teflon liquid as well. You can still get it loose to adjust.
Doug
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2438342
01/21/18 12:40 PM
01/21/18 12:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I always back the adjuster out a bit, hit it with brake clean/compressed air and put a dab of gray RTV on the threads and adjust her up. Even the pickups up to 07 still do this.
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: J_BODY] #2438395
01/21/18 01:56 PM
01/21/18 01:56 PM
BDW Online content
BDW  Online Content
I had to put some RTV on mine too
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2438606
01/21/18 08:39 PM
01/21/18 08:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2439073
01/22/18 04:16 PM
01/22/18 04:16 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I used a part very similar to what John posted under mine and it worked great. I got mine at a local Chevrolet dealership, but cant remember the exact part usage.
Matt
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2439183
01/22/18 08:21 PM
01/22/18 08:21 PM
Guitar Jones Offline
I've never had a problem with them leaking. It's only going to leak when it's shut off and the converter leaks down.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: Guitar Jones] #2439197
01/22/18 09:03 PM
01/22/18 09:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've never figured out why some leak and most don't...even with the elevated fluid level caused by converter drain back. No choice but to treat the symptom.
Re: 727 Adjuster screw leaking - O-ring seal fix? [Re: grancuda] #2439570
01/23/18 03:03 PM
01/23/18 03:03 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Some don't leak, some do leak, and it's When driving not just sitting.
