727 Adjuster screw leaking - O-ring seal fix?
#2438107
01/20/18 08:43 PM
01/20/18 08:43 PM
Posts: 1,005 Central US
grancuda
Central US
Is there a o-ring under thats under the adjuster screw nut? Cleaned up/power washed an old 727 with 60k mile on it & going to stick it in a SWB D100. It's just been sitting in the shop since I washed it & it's leaking from that adjuster screw. Any ideas?
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: 727 Adjuster screw leaking - O-ring seal fix?
[Re: grancuda]
#2438115
01/20/18 09:13 PM
01/20/18 09:13 PM
Posts: 21,399 It's a dry heat
gtx6970
It's a dry heat
No O ring.
I just use pipe thread sealant. The one in the tube. not the tape.
Aka - white thread lock
[Re: grancuda]
#2438124
01/20/18 09:32 PM
01/20/18 09:32 PM
Posts: 5,774 ohio
ruderunner
ohio
Solution 40 anaerobic sealant.
Angry white pureblood male
[Re: J_BODY]
#2438395
01/21/18 01:56 PM
01/21/18 01:56 PM
Posts: 4,707 Florida
BDW
I always back the adjuster out a bit, hit it with brake clean/compressed air and put a dab of gray RTV on the threads and adjust her up. Even the pickups up to 07 still do this. I had to put some RTV on mine too
[Re: grancuda]
#2439183
01/22/18 08:21 PM
01/22/18 08:21 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I've never had a problem with them leaking. It's only going to leak when it's shut off and the converter leaks down.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2439197
01/22/18 09:03 PM
01/22/18 09:03 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've never figured out why some leak and most don't...even with the elevated fluid level caused by converter drain back. No choice but to treat the symptom.
