1967 GTX #2438861
01/22/18 04:09 AM
01/22/18 04:09 AM
Alaska
Reason Offline OP
Reason  Offline OP
Alaska
I’m needing some help on my restoration project. I’m looking for information and pictures for proper coil power for battery and ignition power. I’ve been working on this car for several years and am so close.... But I’m lacking a few important details on the coil and distributor wiring. The new harness I have doesn’t have them included and I can’t find pictures or info anywhere...
Re: 1967 GTX [Re: Reason] #2438869
01/22/18 05:23 AM
01/22/18 05:23 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
What is the motor and accessories, i.e. ac?
Re: 1967 GTX [Re: Reason] #2439186
01/22/18 08:34 PM
01/22/18 08:34 PM
Alaska
Reason Offline OP
Reason  Offline OP
Alaska
Thanks for getting back to me. Sorry... I did forget to add a few crucial items.
It is a 1967 GTX with the 440-auto and power steering and no A/C. The old engine wiring harness didn't have the coil/ignition provision when I removed it, so I don't have a reference point to go by.
The car was purchased with engine/trans and body work complete, so my son and I are having the pleasure of putting everything back together that we didn't take apart...
Any help would be greatly appreciated!
Russ
Re: 1967 GTX [Re: Reason] #2439190
01/22/18 08:48 PM
01/22/18 08:48 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Do you still have the old harness? Was the coil power totally removed?
Re: 1967 GTX [Re: Reason] #2439211
01/22/18 09:33 PM
01/22/18 09:33 PM
Alaska
Reason Offline OP
Reason  Offline OP
Alaska
I do have the old harness, and there isn't anything there for coil or distributor. oddly enough, the harness was still installed as well... It
sure had my thinker going. I have all the manuals, and the wiring diagrams as well. However... the wiring diagram's I have show the coil power wire to be a grey wire coming off of the harness... Neither harness I have, have the grey wire for power. The only extra wire is the blue wire for the A/C compressor lockup control...
Re: 1967 GTX [Re: Reason] #2439214
01/22/18 09:36 PM
01/22/18 09:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Having a factory service manual will save you a ton of headaches.
If I understand your question, and if I remember correctly, my '67 GTX was the same as my '68-'70 Bs in this regard: coil wire runs along the inner side of the pass (right) valve cover, where those tabs are; #8 plug wire also runs along there.
Photos of installed engines & engine compartments can be found on Google: search "67 GTX engine compartment images".
Re: 1967 GTX [Re: Reason] #2439291
01/23/18 12:25 AM
01/23/18 12:25 AM
Alaska
Reason Offline OP
Reason  Offline OP
Alaska
Thank you! I'll look and see what I can find. I do have all the manuals for the car, but the only item section that does not have an exploded view is the engine compartment... Go figure...
Thanks again!!
Re: 1967 GTX [Re: Reason] #2439566
01/23/18 02:58 PM
01/23/18 02:58 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The coil wire comes out of the harness near the center of the valve cover. It is then routed forward for big block and rearward for small block. It is blue in color, not light or dark.
It could be they cut it off. Might have to open the wrap to find it.
Re: 1967 GTX [Re: Reason] #2439603
01/23/18 04:10 PM
01/23/18 04:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
...and if I remember correctly, grey wire is for oil pressure sender @ rear of engine, left of center.
Sub-harness for horns, washer pump & alternator runs along the depression in rt apron, retained by plastic push-in straps.
Battery + & ft lamp harness run along similar contour on lt apron, same retainers. Brake pressure wire drops down from there near firewall.
Re: 1967 GTX [Re: Reason] #2439806
01/24/18 12:22 AM
01/24/18 12:22 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Incorrect above.
The horn, washer pump, and alt wires are all in the engine harness. It runs along the valve cover, behind/under alt and to the horns and relay.
There are no wires that run along the right fender apron on any V8 non AC 1967 Plymouth/Dodge B-body. I don't know about /6 or AC cars.
Re: 1967 GTX [Re: Reason] #2440052
01/24/18 03:15 PM
01/24/18 03:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Oops, sorry for the mis-info, then. I'll bow out.
