71 B body w/Hemi and a/c #2438407
01/21/18 02:26 PM
01/21/18 02:26 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
I have a 71 RR340 w/ac. I would like to put a single 4bbl 426H in it, however it looks like the a/c lines coming out of the firewall might have interference with the valve covers, maybe not even enough room for 90 degree fittings. Anyone have engine compartment pics of a 71 Hemi B-body. Thanks, Steve
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2438418
01/21/18 02:45 PM
01/21/18 02:45 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You can make anything work, but there was a reason you couldn't get a Hemi with air.
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2438420
01/21/18 02:47 PM
01/21/18 02:47 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
a friend of mine used to own a 71 charger with a 612 hemi in it. other than trimming the air cleaner everything bolted on.
he used indy heads and intake.
here is his old car on youtube. the new owner is driving the car in the videos. the car is in Sweden now.
https://www.youtube.com/watch?v=GfqSR_ocVBs
https://www.youtube.com/watch?v=wEIJMZAMvvQ
perception is 90% of reality
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2438428
01/21/18 02:56 PM
01/21/18 02:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The 71 B body G-Series wingcars that I built/fabricated were HEMI equipped running Sanden compressors positioned under the alternator, all the firewall AC components were factory issue
Mike
Re: 71 B body w/Hemi and a/c [Re: DAYCLONA] #2438431
01/21/18 02:58 PM
01/21/18 02:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a Monteverdi (IIRC) running HEMI power with factory AC
Mike
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2438444
01/21/18 03:26 PM
01/21/18 03:26 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
A/C outlets are not in the way on those or e bodies.
Re: 71 B body w/Hemi and a/c [Re: DAYCLONA] #2438472
01/21/18 04:33 PM
01/21/18 04:33 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Would like to see more of this Monteverdi.
I have mechanical Aptitude.
I can screw up anything.
Re: 71 B body w/Hemi and a/c [Re: 71birdJ68] #2438479
01/21/18 04:48 PM
01/21/18 04:48 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and 6packs
Re: 71 B body w/Hemi and a/c [Re: NachoRT74] #2438482
01/21/18 04:52 PM
01/21/18 04:52 PM
Mr T2U Offline
Mr T2U  Offline
and 6packs
A/C wasn't available because the A/C compressor hits the air cleaner.
trim the air cleaner base and you can have A/C on your hemi or 440+6 car.
Re: 71 B body w/Hemi and a/c [Re: Mr T2U] #2438487
01/21/18 05:05 PM
01/21/18 05:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
and 6packs
It wasn't available due to expected RPM use. Didn't want ricky the racer blowing up his AC compressor trying to win and not be sweaty. The factory was more than smart enough to figure out how to trim the air cleaner housing.
Don't be the exception.
Re: 71 B body w/Hemi and a/c [Re: bboogieart] #2438611
01/21/18 08:47 PM
01/21/18 08:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
more pics/info here: https://www.allpar.com/cars/adopted/misc/monteverdi-hai.html
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2438646
01/21/18 09:33 PM
01/21/18 09:33 PM
Chicago
PurpleBeeper Offline
Chicago
It can totally be done & I like the "Sanden compressor under the alternator" idea myself. MANY years ago I bought a six pack air cleaner that had been trimmed to clear a factory A/C compressor, so this type of thing has been done for a long time...you wouldn't be the first by any stretch.
I'm no expert on this, but I would suggest you put a lot of consideration into your engine cooling system & keep the motor relatively mild.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 71 B body w/Hemi and a/c [Re: Supercuda] #2438653
01/21/18 09:42 PM
01/21/18 09:42 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I've often heard that but I believe the 383 has equal/more RPM potential.
Re: 71 B body w/Hemi and a/c [Re: John_Kunkel] #2438659
01/21/18 09:45 PM
01/21/18 09:45 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
340 has a higher redline and a/c was available on them soooooo.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2438664
01/21/18 09:49 PM
01/21/18 09:49 PM
moparmarks Offline
moparmarks  Offline
If you want to hack up a 1500.00 base plate set then you can make the old a/c compressor work with the shaker and a single carb. This is a 340 here. Not with multiple carbs though.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 B body w/Hemi and a/c [Re: bboogieart] #2438689
01/21/18 10:13 PM
01/21/18 10:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I took and posted that picture here on moparts years ago.
Re: 71 B body w/Hemi and a/c [Re: DAYCLONA] #2438990
01/22/18 02:12 PM
01/22/18 02:12 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Mike
Did you have to ditch the factory mech. Fuel pump to run the a.c. under the alt.? Pics showing how you had it mounted?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 71 B body w/Hemi and a/c [Re: toplescuda] #2439025
01/22/18 03:21 PM
01/22/18 03:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Yes the aftermarket kit uses the fuel pump boss for the front mount, which was ok in these applications as we had decided to run an electric pump from the start of the project
Mike
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2439068
01/22/18 04:12 PM
01/22/18 04:12 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
Thanks for all the replies. I will not running the Airtemp compressor, Engine will be a 472 w/solid cam and the Mopar dp intake, About what the crate motor from Mopar was. Nothing radical. Car has the original 26" rad probably needs re-cored anyway. It's not a fresh air car. The 340 in the car is tired Iv'e got everything besides heads and crank from having a complete 426H, But it's the only A/C hobby car I got and would stay a 340 if butchery was involved. FWIW a friend bought a spirit of 76 d-150 new, 318 auto with air, within 2 wks of purchase it rolled out of his garage with a 68 426 and still with air.
Re: 71 B body w/Hemi and a/c [Re: Handygun] #2439237
01/22/18 10:24 PM
01/22/18 10:24 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
https://www.facebook.com/606715996023750...2065440/?type=3
we make the above kit with mechanical water pump or electric water pump. this is still in the mock up phase but the few that are out testing are working really well
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
