Re: 71 B body w/Hemi and a/c
[Re: Handygun]
#2438428
01/21/18 02:56 PM
01/21/18 02:56 PM
Posts: 18,153 Mass
DAYCLONA
Mass
I have a 71 RR340 w/ac. I would like to put a single 4bbl 426H in it, however it looks like the a/c lines coming out of the firewall might have interference with the valve covers, maybe not even enough room for 90 degree fittings. Anyone have engine compartment pics of a 71 Hemi B-body. Thanks, Steve The 71 B body G-Series wingcars that I built/fabricated were HEMI equipped running Sanden compressors positioned under the alternator, all the firewall AC components were factory issue Mike
[Re: 71birdJ68]
#2438479
01/21/18 04:48 PM
01/21/18 04:48 PM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
You can make anything work, but there was a reason you couldn't get a Hemi with air. and 6packs
[Re: NachoRT74]
#2438482
01/21/18 04:52 PM
01/21/18 04:52 PM
Posts: 4,909 new berlin wisconsin
Mr T2U
You can make anything work, but there was a reason you couldn't get a Hemi with air. and 6packs A/C wasn't available because the A/C compressor hits the air cleaner. trim the air cleaner base and you can have A/C on your hemi or 440+6 car.
perception is 90% of reality
[Re: Mr T2U]
#2438487
01/21/18 05:05 PM
01/21/18 05:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You can make anything work, but there was a reason you couldn't get a Hemi with air. and 6packs A/C wasn't available because the A/C compressor hits the air cleaner. trim the air cleaner base and you can have A/C on your hemi or 440+6 car. It wasn't available due to expected RPM use. Didn't want ricky the racer blowing up his AC compressor trying to win and not be sweaty. The factory was more than smart enough to figure out how to trim the air cleaner housing.
[Re: Handygun]
#2438646
01/21/18 09:33 PM
01/21/18 09:33 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
It can totally be done & I like the "Sanden compressor under the alternator" idea myself. MANY years ago I bought a six pack air cleaner that had been trimmed to clear a factory A/C compressor, so this type of thing has been done for a long time...you wouldn't be the first by any stretch.
I'm no expert on this, but I would suggest you put a lot of consideration into your engine cooling system & keep the motor relatively mild.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Supercuda]
#2438653
01/21/18 09:42 PM
01/21/18 09:42 PM
Posts: 25,591 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've often heard that but I believe the 383 has equal/more RPM potential.
[Re: Handygun]
#2438664
01/21/18 09:49 PM
01/21/18 09:49 PM
Posts: 12,483 Western Colorado High Desert
moparmarks
If you want to hack up a 1500.00 base plate set then you can make the old a/c compressor work with the shaker and a single carb. This is a 340 here. Not with multiple carbs though.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: bboogieart]
#2438689
01/21/18 10:13 PM
01/21/18 10:13 PM
Posts: 27,442 So Cal
autoxcuda
So Cal
Would like to see more of this Monteverdi. I took and posted that picture here on moparts years ago.
[Re: DAYCLONA]
#2438990
01/22/18 02:12 PM
01/22/18 02:12 PM
Posts: 8,840 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I have a 71 RR340 w/ac. I would like to put a single 4bbl 426H in it, however it looks like the a/c lines coming out of the firewall might have interference with the valve covers, maybe not even enough room for 90 degree fittings. Anyone have engine compartment pics of a 71 Hemi B-body. Thanks, Steve The 71 B body G-Series wingcars that I built/fabricated were HEMI equipped running Sanden compressors positioned under the alternator, all the firewall AC components were factory issue Mike Did you have to ditch the factory mech. Fuel pump to run the a.c. under the alt.? Pics showing how you had it mounted?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2439025
01/22/18 03:21 PM
01/22/18 03:21 PM
Posts: 18,153 Mass
DAYCLONA
Mass
I have a 71 RR340 w/ac. I would like to put a single 4bbl 426H in it, however it looks like the a/c lines coming out of the firewall might have interference with the valve covers, maybe not even enough room for 90 degree fittings. Anyone have engine compartment pics of a 71 Hemi B-body. Thanks, Steve The 71 B body G-Series wingcars that I built/fabricated were HEMI equipped running Sanden compressors positioned under the alternator, all the firewall AC components were factory issue Mike Did you have to ditch the factory mech. Fuel pump to run the a.c. under the alt.? Pics showing how you had it mounted? Yes the aftermarket kit uses the fuel pump boss for the front mount, which was ok in these applications as we had decided to run an electric pump from the start of the project Mike
