Best bang for the buck 440 heads and rods #2438792
01/22/18 12:36 AM
01/22/18 12:36 AM
Dirty Dena, Maryland
dodge turbo Offline OP
Thinking about ditching my small block turbo set up and going to a 440
Small block runs great but I wanna go faster lol
And im cheap so looking for ideas
Thanks!
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2438796
01/22/18 12:43 AM
01/22/18 12:43 AM
Kirkland, Washington
Pacnorthcuda Offline
Well, as far as "bang for the buck 440 heads" you're going to hear "440 Source".
I run em, ditched the old 906's. No complaints
Re: Best bang for the buck 440 heads and rods [Re: Pacnorthcuda] #2438843
01/22/18 02:57 AM
01/22/18 02:57 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
RPM for the rods.
There is a B1 setup ready to run on racingjunk for $3500. If you already have to make the exhaust you might as well get exotic right?
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2438849
01/22/18 03:18 AM
01/22/18 03:18 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Originally Posted By dodge turbo
I wanna go faster
And im cheap
GM Perf...
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2438908
01/22/18 11:27 AM
01/22/18 11:27 AM
GM lol.... I know right
I wanna keep it mopar... boost makes up for what it lacks
Re: Best bang for the buck 440 heads and rods [Re: RSNOMO] #2438913
01/22/18 11:36 AM
01/22/18 11:36 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I wanna go faster
And im cheap
GM Perf...
They make 440s work The things ya learn.
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439181
01/22/18 08:17 PM
01/22/18 08:17 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Seeing what dizuster does with a cast crank, stock stroke 360 with a single turbo I'd be looking to replicate that if you want to go faster.
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439208
01/22/18 09:24 PM
01/22/18 09:24 PM
gregsdart Offline
gregsdart  Offline
A stock 360 magnum with some boost will hit 450 hp or better i am sure. A friend of mine pushed a nonintercooled boneyard 318 to 534 hp before he lost a head gasket! You say cheap, it is darn hard to beat the power per $ a turbo can give you. Besides , they work well with less converter and road gears!
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439227
01/22/18 10:02 PM
01/22/18 10:02 PM
Im already turbo’d small block ...been for years
And it makes close to 700 rwhp
I want to go big block and make more power then 700 at a lower boost level
And go faster smh
Re: Best bang for the buck 440 heads and rods [Re: gregsdart] #2439232
01/22/18 10:15 PM
01/22/18 10:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Exactly what I was thinking, maybe a bigger turbo or better cam then what you have. You're not going to get a bucks down better package than where you're at now.
Me personably, I would spend the money on a 5.7 Hemi and turbo. Should go easily in your truck. Hot Rod did a build-test awhile back with a stock junkyard engine and a turbo they had used on another engine, made way over 500 hp. With bolt on stuff.
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439357
01/23/18 02:11 AM
01/23/18 02:11 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
And go faster smh
To do that you are going to need an aftermarket block, not cheap.
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439620
01/23/18 04:55 PM
01/23/18 04:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Have the first run of 440 Sources on my built 440.been on for years.No problems.I did change springs,retainers,and keepers because of my .588 solid cam.Rocky
Chrysler Firepower
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439627
01/23/18 05:13 PM
01/23/18 05:13 PM
Those are some very impressive results bow
My N/A 518 C.I. low deck pump gas stroker made 727 HP at the flywheel, a little over 500 RWHP, it weighed 3450 Lbs. with me in it and ran a best of 9.993 at 134.7 MPH through the 3.0 inch exhaust with the air cleaner on boogie
Adding 3 to 7.0 lbs of boost on pump swill might have got it into the low tens or high nines, who knows confused
That was a regular non thick web 1976 400 block with four sleeves in it and ductile iron main caps and ARP main studs, no girdle tsk Indy SR M.W. non ported heads with a Indy 400-3 intake and Holley # 9375 non HP Dominator carb. up
I would NOT buy the cheapest rods I could get tsk
On the heads as you already know they can limit how much air can be forced through them, huh work shruggy
Bottom lines is how fast do you want to go and how much money and effort do you want to spend to get thier shruggy
Do it cheap and redo it later to go faster or do it once and go fast right away work grin
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439774
01/23/18 10:45 PM
01/23/18 10:45 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
Thanks!
Used, always cheaper than new, initially. grin
1974 Roadrunner
1967 Charger
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439839
01/24/18 01:17 AM
01/24/18 01:17 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Just put better heads on the small block.
Kevin
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2439966
01/24/18 12:50 PM
01/24/18 12:50 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
G3 hemi, best factory blocks, since the turbo is making the power, your goal is buying a block that can live. S/F....Ken M
Re: Best bang for the buck 440 heads and rods [Re: Skeptic] #2440076
01/24/18 03:47 PM
01/24/18 03:47 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I wanna go faster
And im cheap
GM Perf...
Well they make 383s so..... stirthepot
71 440-6 4spd & 69 Hemi 4spd
Re: Best bang for the buck 440 heads and rods [Re: hemi_doug] #2440305
01/24/18 11:54 PM
01/24/18 11:54 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
haha So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker.
Re: Best bang for the buck 440 heads and rods [Re: Skeptic] #2440352
01/25/18 01:49 AM
01/25/18 01:49 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
They also built low deck 383's and tall deck 383's, just to be confusing.
Re: Best bang for the buck 440 heads and rods [Re: John Brown] #2440406
01/25/18 04:01 AM
01/25/18 04:01 AM
1959 only year made I think, tall deck 383 where I believe 4.0 bore with a 3.75 stroke, the low decks where like all the other normal low deck 383, 4.250 bore with the shorter stroke up
Never say never with any American car company, NEVER tsk whistling grin
