Best bang for the buck 440 heads and rods
#2438792
01/22/18 12:36 AM
01/22/18 12:36 AM
Posts: 468 Dirty Dena, Maryland
dodge turbo
Thinking about ditching my small block turbo set up and going to a 440
Small block runs great but I wanna go faster lol
And im cheap so looking for ideas
Thanks!
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Best bang for the buck 440 heads and rods
[Re: dodge turbo]
#2438849
01/22/18 03:18 AM
01/22/18 03:18 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I wanna go faster
And im cheap GM Perf...
[Re: dodge turbo]
#2438908
01/22/18 11:27 AM
01/22/18 11:27 AM
dodge turbo
GM lol.... I know right
I wanna keep it mopar... boost makes up for what it lacks
[Re: RSNOMO]
#2438913
01/22/18 11:36 AM
01/22/18 11:36 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I wanna go faster
And im cheap GM Perf... They make 440s ![work work](/ubbthreads/images/graemlins/custom/work.gif) The things ya learn.
[Re: dodge turbo]
#2439181
01/22/18 08:17 PM
01/22/18 08:17 PM
Posts: 4,451 Michigan
MarkZ
Worthy
Worthy
Seeing what dizuster does with a cast crank, stock stroke 360 with a single turbo I'd be looking to replicate that if you want to go faster.
[Re: dodge turbo]
#2439208
01/22/18 09:24 PM
01/22/18 09:24 PM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A stock 360 magnum with some boost will hit 450 hp or better i am sure. A friend of mine pushed a nonintercooled boneyard 318 to 534 hp before he lost a head gasket! You say cheap, it is darn hard to beat the power per $ a turbo can give you. Besides , they work well with less converter and road gears!
[Re: dodge turbo]
#2439227
01/22/18 10:02 PM
01/22/18 10:02 PM
dodge turbo
Im already turbo’d small block ...been for years And it makes close to 700 rwhp
I want to go big block and make more power then 700 at a lower boost level And go faster smh
[Re: gregsdart]
#2439232
01/22/18 10:15 PM
01/22/18 10:15 PM
Posts: 8,349 fredericksburg,va
cudaman1969
fredericksburg,va
A stock 360 magnum with some boost will hit 450 hp or better i am sure. A friend of mine pushed a nonintercooled boneyard 318 to 534 hp before he lost a head gasket! You say cheap, it is darn hard to beat the power per $ a turbo can give you. Besides , they work well with less converter and road gears! Exactly what I was thinking, maybe a bigger turbo or better cam then what you have. You're not going to get a bucks down better package than where you're at now. Me personably, I would spend the money on a 5.7 Hemi and turbo. Should go easily in your truck. Hot Rod did a build-test awhile back with a stock junkyard engine and a turbo they had used on another engine, made way over 500 hp. With bolt on stuff.
[Re: dodge turbo]
#2439357
01/23/18 02:11 AM
01/23/18 02:11 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
To do that you are going to need an aftermarket block, not cheap.
[Re: dodge turbo]
#2439620
01/23/18 04:55 PM
01/23/18 04:55 PM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
Have the first run of 440 Sources on my built 440.been on for years.No problems.I did change springs,retainers,and keepers because of my .588 solid cam.Rocky
Chrysler Firepower
[Re: dodge turbo]
#2439627
01/23/18 05:13 PM
01/23/18 05:13 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Im already turbo’d small block ...been for years And it makes close to 700 rwhp Those are some very impressive results ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif) My N/A 518 C.I. low deck pump gas stroker made 727 HP at the flywheel, a little over 500 RWHP, it weighed 3450 Lbs. with me in it and ran a best of 9.993 at 134.7 MPH through the 3.0 inch exhaust with the air cleaner on Adding 3 to 7.0 lbs of boost on pump swill might have got it into the low tens or high nines, who knows That was a regular non thick web 1976 400 block with four sleeves in it and ductile iron main caps and ARP main studs, no girdle ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) Indy SR M.W. non ported heads with a Indy 400-3 intake and Holley # 9375 non HP Dominator carb. I would NOT buy the cheapest rods I could get ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) On the heads as you already know they can limit how much air can be forced through them, huh ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Bottom lines is how fast do you want to go and how much money and effort do you want to spend to get thier ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Do it cheap and redo it later to go faster or do it once and go fast right away ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: dodge turbo]
#2439774
01/23/18 10:45 PM
01/23/18 10:45 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Thanks! Used, always cheaper than new, initially. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
1974 Roadrunner
1967 Charger
[Re: Skeptic]
#2440076
01/24/18 03:47 PM
01/24/18 03:47 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
I wanna go faster
And im cheap GM Perf... They make 440s ![work work](/ubbthreads/images/graemlins/custom/work.gif) The things ya learn. Well they make 383s so..... ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif)
71 440-6 4spd & 69 Hemi 4spd
[Re: Skeptic]
#2440352
01/25/18 01:49 AM
01/25/18 01:49 AM
Posts: 1,849 South Bend
John Brown
South Bend
![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. They also built low deck 383's and tall deck 383's, just to be confusing.
[Re: John Brown]
#2440406
01/25/18 04:01 AM
01/25/18 04:01 AM
Cab_Burge
![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. They also built low deck 383's and tall deck 383's, just to be confusing. 1959 only year made I think, tall deck 383 where I believe 4.0 bore with a 3.75 stroke, the low decks where like all the other normal low deck 383, 4.250 bore with the shorter stroke Never say never with any American car company, NEVER ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
