Best bang for the buck 440 heads and rods
#2438792
01/22/18 12:36 AM
01/22/18 12:36 AM
Posts: 468 Dirty Dena, Maryland
dodge turbo
Thinking about ditching my small block turbo set up and going to a 440
Small block runs great but I wanna go faster lol
And im cheap so looking for ideas
Thanks!
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Best bang for the buck 440 heads and rods
[Re: dodge turbo]
#2438849
01/22/18 03:18 AM
01/22/18 03:18 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I wanna go faster
And im cheap GM Perf...
[Re: dodge turbo]
#2438908
01/22/18 11:27 AM
01/22/18 11:27 AM
dodge turbo
GM lol.... I know right
I wanna keep it mopar... boost makes up for what it lacks
[Re: RSNOMO]
#2438913
01/22/18 11:36 AM
01/22/18 11:36 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I wanna go faster
And im cheap GM Perf... They make 440s The things ya learn.
[Re: dodge turbo]
#2439181
01/22/18 08:17 PM
01/22/18 08:17 PM
Posts: 4,430 Michigan
MarkZ
Worthy
Worthy
Seeing what dizuster does with a cast crank, stock stroke 360 with a single turbo I'd be looking to replicate that if you want to go faster.
[Re: dodge turbo]
#2439208
01/22/18 09:24 PM
01/22/18 09:24 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A stock 360 magnum with some boost will hit 450 hp or better i am sure. A friend of mine pushed a nonintercooled boneyard 318 to 534 hp before he lost a head gasket! You say cheap, it is darn hard to beat the power per $ a turbo can give you. Besides , they work well with less converter and road gears!
[Re: dodge turbo]
#2439227
01/22/18 10:02 PM
01/22/18 10:02 PM
dodge turbo
Im already turbo’d small block ...been for years And it makes close to 700 rwhp
I want to go big block and make more power then 700 at a lower boost level And go faster smh
[Re: gregsdart]
#2439232
01/22/18 10:15 PM
01/22/18 10:15 PM
Posts: 8,282 fredericksburg,va
cudaman1969
fredericksburg,va
A stock 360 magnum with some boost will hit 450 hp or better i am sure. A friend of mine pushed a nonintercooled boneyard 318 to 534 hp before he lost a head gasket! You say cheap, it is darn hard to beat the power per $ a turbo can give you. Besides , they work well with less converter and road gears! Exactly what I was thinking, maybe a bigger turbo or better cam then what you have. You're not going to get a bucks down better package than where you're at now. Me personably, I would spend the money on a 5.7 Hemi and turbo. Should go easily in your truck. Hot Rod did a build-test awhile back with a stock junkyard engine and a turbo they had used on another engine, made way over 500 hp. With bolt on stuff.
[Re: dodge turbo]
#2439357
01/23/18 02:11 AM
01/23/18 02:11 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
To do that you are going to need an aftermarket block, not cheap.
[Re: dodge turbo]
#2439620
01/23/18 04:55 PM
01/23/18 04:55 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Have the first run of 440 Sources on my built 440.been on for years.No problems.I did change springs,retainers,and keepers because of my .588 solid cam.Rocky
Chrysler Firepower
[Re: dodge turbo]
#2439627
01/23/18 05:13 PM
01/23/18 05:13 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
Im already turbo’d small block ...been for years And it makes close to 700 rwhp Those are some very impressive results My N/A 518 C.I. low deck pump gas stroker made 727 HP at the flywheel, a little over 500 RWHP, it weighed 3450 Lbs. with me in it and ran a best of 9.993 at 134.7 MPH through the 3.0 inch exhaust with the air cleaner on Adding 3 to 7.0 lbs of boost on pump swill might have got it into the low tens or high nines, who knows That was a regular non thick web 1976 400 block with four sleeves in it and ductile iron main caps and ARP main studs, no girdle Indy SR M.W. non ported heads with a Indy 400-3 intake and Holley # 9375 non HP Dominator carb. I would NOT buy the cheapest rods I could get On the heads as you already know they can limit how much air can be forced through them, huh Bottom lines is how fast do you want to go and how much money and effort do you want to spend to get thier Do it cheap and redo it later to go faster or do it once and go fast right away
[Re: dodge turbo]
#2439774
01/23/18 10:45 PM
01/23/18 10:45 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Thanks! Used, always cheaper than new, initially.
1974 Roadrunner
1967 Charger
[Re: Skeptic]
#2440076
01/24/18 03:47 PM
01/24/18 03:47 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
I wanna go faster
And im cheap GM Perf... They make 440s The things ya learn. Well they make 383s so.....
71 440-6 4spd & 69 Hemi 4spd
[Re: Skeptic]
#2440352
01/25/18 01:49 AM
01/25/18 01:49 AM
Posts: 1,835 South Bend
John Brown
South Bend
So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. They also built low deck 383's and tall deck 383's, just to be confusing.
[Re: John Brown]
#2440406
01/25/18 04:01 AM
01/25/18 04:01 AM
Cab_Burge
So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. They also built low deck 383's and tall deck 383's, just to be confusing. 1959 only year made I think, tall deck 383 where I believe 4.0 bore with a 3.75 stroke, the low decks where like all the other normal low deck 383, 4.250 bore with the shorter stroke Never say never with any American car company, NEVER
