Fuel line and return size #2438491
01/21/18 05:25 PM
01/21/18 05:25 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Hey guys, I upgraded to a stroked 512 last summer and now I'm looking to upgrade the fuel line with PTFE braided stainless. Factory lines are 5/16" supply with a 3/16" return. Motor is pretty docile with having untouched Eddie heads and a 239 @ .050" roller cam in it. Future plans include pulling the heads off for CNC porting and a 600HP FiTech - won't be going beyond that, so room for upgrades beyond this level would be unneeded.
I was thinking 3/8" supply and 1/4" return. Opinions? Thanks guys!
Re: Fuel line and return size [Re: MarkZ] #2438494
01/21/18 05:32 PM
01/21/18 05:32 PM
BDW Offline
BDW  Offline
I'm not near your power level, but when I added the 600hp Fitech, added a 3/8" line for fuel and used the factory 5/16" for the return.
That way you're only adding 1 line.
Re: Fuel line and return size [Re: MarkZ] #2438496
01/21/18 05:33 PM
01/21/18 05:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When I build a return system I usually use the original supply as the return and upsize the new supply. So I'd got with the 3/8" supply and use the existing 5/16" as a return. You really can't go too big on the return, within reason in case some clown want's to mwntion 2" black pipe or some such silliness.
Don't be the exception.
Re: Fuel line and return size [Re: MarkZ] #2438497
01/21/18 05:34 PM
01/21/18 05:34 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I would absolutely not use 1/4" retuirn. If you use 3/8 feed use the same for the return. Absolutely would make the return at least 5/16.
I am building a 69 GTX with a 505 about 700 hp. I am running 8 AN (1/2") feed and return. Aeromotive tech support agreed with these sizes.
Re: Fuel line and return size [Re: MarkZ] #2438591
01/21/18 08:18 PM
01/21/18 08:18 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
If using a high flow,volume electric pump I would use a 3/8 supply,3/8 return, that is how my car is, 5/16 is ok for EFI, because it runs a much higher pressure, but for a carb,3/8 would be better for a return, mine is carb for now.
Re: Fuel line and return size [Re: MarkZ] #2438650
01/21/18 09:37 PM
01/21/18 09:37 PM
Chicago
PurpleBeeper Offline
Chicago
I personally like the idea of using the stock 5/16" line as a fuel return. It's already there, well-routed & simple.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Fuel line and return size [Re: PurpleBeeper] #2438725
01/21/18 11:02 PM
01/21/18 11:02 PM
IN
ahy Offline
ahy  Offline
IN
On my 496 I run 3/8" supply and 5/16" return. It is EFI. Works fine. Carb style regulators may like a bigger return. IDK.
For what it is worth, I like and run stock style steel lines (mostly). Tough, cost effective and they route well in the rear which can be tough. I use braided racing hose at the ends to hook everything up.
Re: Fuel line and return size [Re: MarkZ] #2438736
01/21/18 11:11 PM
01/21/18 11:11 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I should have stated that I plan on using an in-tank pump like the Aeromotive 340 when I change over. I'm just not a fan of the under hood surge tank FiTech sells. It'll be a another season though before that happens. Just trying to get the lines in order this year.
Thanks for the input everyone. This forum has been invaluable to me over the years.
Re: Fuel line and return size [Re: MarkZ] #2441483
01/27/18 02:06 PM
01/27/18 02:06 PM
Opelika, AL
JRs_Charger Offline
JRs_Charger  Offline
Opelika, AL
I have the 600 HP FItech, and an in tank pump, and use 3/8th line for both feed and return. The large return line seems to help keep fuel temps lower.
The 5/16 and 1/4 lines are a no go.
Re: Fuel line and return size [Re: JRs_Charger] #2441503
01/27/18 02:37 PM
01/27/18 02:37 PM
BDW Offline
BDW  Offline
I have exact set-up, 600 HP Fitech with Spectra tank with in tank pump.
Added 3/8" line for feed and used existing 5/16" for return. Works perfectly.
Curious why you say it's "no go"?
Nice thing about Fitech is you can adjust the voltage to the fuel pump , PWM, to lower the fuel pressure if needed.
Re: Fuel line and return size [Re: BDW] #2441869
01/28/18 12:44 AM
01/28/18 12:44 AM
Opelika, AL
JRs_Charger Offline
JRs_Charger  Offline
Opelika, AL
I'm sorry, I meant the specific combination of 5/16 feed and 1/4 return line is a no go. That would overheat and kill the fuel pump very quickly.
Here's a helpful article where Aeromotive recommends certain line sizes for different horsepower engines.
http://www.stangtv.com/features/fuel-system-troubleshooting-killing-gremlins-with-aeromotive/
