Hemi ARP bolts #2438396
01/21/18 01:57 PM
01/21/18 01:57 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Been meaning to ask for awhile, do they make different length 426 Hemi head bolts? Reason being after test fitting the head, the under intake bolts seam too short, blocks been decked 1/8. I run a fair amount up in the head and then with washer on hardly any threads left for the nut. Anyone else run into this problem?
Re: Hemi ARP bolts [Re: cudaman1969] #2438423
01/21/18 02:49 PM
01/21/18 02:49 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
They didn't use bolts under the intake, they were studs.
Re: Hemi ARP bolts [Re: cudaman1969] #2438424
01/21/18 02:49 PM
01/21/18 02:49 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
World style block? They use a longer valley boss than stock
Re: Hemi ARP bolts [Re: cudaman1969] #2438544
01/21/18 07:23 PM
01/21/18 07:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yes.....
Different block & head combos use different bolts and studs. It can get expensive quick if you end up buying the wrong lengths...
Re: Hemi ARP bolts [Re: 71birdJ68] #2438643
01/21/18 09:30 PM
01/21/18 09:30 PM
fredericksburg,va
fredericksburg,va
My god you're so right
Re: Hemi ARP bolts [Re: Dragula] #2438645
01/21/18 09:32 PM
01/21/18 09:32 PM
fredericksburg,va
fredericksburg,va
Originally Posted By Dragula
Yes.....
They came with the package,
but I guess I did buy them.
Thanks for the info
