U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios #2437702
01/19/18 10:46 PM
01/19/18 10:46 PM
cleveland Ohio
mloboda Offline OP
mloboda  Offline OP
cleveland Ohio
US GEAR is now making Pro Gear DANA 60 ring and pinions in these formally unavailable ratios( like not made in the last 20 + years)
5:57
5:86
6:17
Now they just need to add 6:50s !
Thanks US GEAR for keeping the Dana 60 from becoming obsolete!!!!!!!!!!!!!!!!!!!!!!
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2437706
01/19/18 10:50 PM
01/19/18 10:50 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
holy steepness! guess if I were racing 300ft I could dabble in that ratio.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: J_BODY] #2437781
01/20/18 01:33 AM
01/20/18 01:33 AM
oregon
greendart408 Offline
oregon
Cool, now if I could get someone to make a 3.73 pro gear.....
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: greendart408] #2437788
01/20/18 01:47 AM
01/20/18 01:47 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I would flip my car over with a set of those. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2437789
01/20/18 01:48 AM
01/20/18 01:48 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I need a 3.90 pro gear 💩
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2437797
01/20/18 02:15 AM
01/20/18 02:15 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
How about a 4.30
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: rowin4] #2437801
01/20/18 02:20 AM
01/20/18 02:20 AM
oregon
oregon
Originally Posted By rowin4
How about a 4.30
Have them in my car, got them from strange, had to wait awhile to get them.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2437817
01/20/18 02:56 AM
01/20/18 02:56 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The Dana I have I got from under a 55 Chevy 327 4 speed street car, 5.86s, ran a 12 inch slick. This was all back in the mid 70s early 80s. Just about every Chevy in those times had a 5.57 or lower, my friends 64 modified Vette had a 6.86! and sometimes a 7.17! I think it had 6 teeth on the pinion.(Dana) Left the line on the wood, no 2 step! 9000 rpm and up. The one he has now (Gran Am) has a 257 ci with a 7.50 gear. (ford)
I'm a Mopar guy but those cars launching and shifting where music to my ears. Allen said his eyeballs would move back and could see out both doors at the same time.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2437832
01/20/18 04:04 AM
01/20/18 04:04 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
5:57
5:86
6:17
Where the heck are you coming from on this?? No, No, No Drag racers need this steep of gears. ???? Drink another beer and go to bed. up
Now Mud bog races, maybe a good thing.??
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2437837
01/20/18 04:40 AM
01/20/18 04:40 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I wonder if those 5.86 gears are available for the front axles as well.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: RTSrunner] #2437877
01/20/18 12:01 PM
01/20/18 12:01 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I guy I work with has a 69 Camaro with 6.00 gears in it.
It is a 496 ci. Big block Chevy and he sprays it with a 250 shot of Nitrous.
He said it runs 5.20's in the 1/8.
I thought that was way too low a gear for Nitrous.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: Sport440] #2437880
01/20/18 12:15 PM
01/20/18 12:15 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
5:57
5:86
6:17
They are doing this because everyone now wants to run 1/8 mile (half a race) but now want to try and use all their engine to get there quicker. Yep - less breakage that way whistling and yes that is why they are making them!
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: D-50] #2437908
01/20/18 01:21 PM
01/20/18 01:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Think about it, tight converter you need that gear reduction. Have you seen what gear the pro stock boys run? Most mopar engines are dead at 6000 (I know there are a few who buzz them) so I guess they only need those 4.10 gears. What gets me is you have a head that flows 500 cfm and you turn it 7000, a lot left on the table.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: Sport440] #2437927
01/20/18 01:43 PM
01/20/18 01:43 PM
MI
68shifter Offline
68shifter  Offline
MI
5:57
5:86
6:17
You better go watch Mike's small block then. It's not some lazy J headed or even w2 setup. I bet his tach starts at 6k.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2437930
01/20/18 01:48 PM
01/20/18 01:48 PM
Locomotion Offline
Locomotion  Offline
I know a guy with a Super Stock 318 Aspen that uses mid-high 5.xx ratios and it wouldn't surprise me if a 5.38 could be used in a Stock class 340 stick car in the 1/4. Heavier cars can sometimes use more ratio also.
Maybe enough people are getting away from the more expensive and less efficient Ford 9", making these Dana 60 ratios worthwhile to manufacture.
Comp cars and what use to be Modified production like all that ratio too with their itty bitty engines.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: Sport440] #2437943
01/20/18 02:09 PM
01/20/18 02:09 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
We have run a 5:56 Dana for longer than I can remember in a drag race car. It is not unusual to see folks looking for the ratios above for drag race cars.
With 32 and 33 inch tall tires the effective ratio is higher than you would think.
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: Locomotion] #2439032
01/22/18 03:26 PM
01/22/18 03:26 PM
fla
ss/la Offline
ss/la  Offline
fla
I wish they would make a dana 60 gear around 6:30 or 6:40 I could use a little more rpm on top
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: mloboda] #2439039
01/22/18 03:36 PM
01/22/18 03:36 PM
an8sec70cuda Offline
Even w/ big tires on an 1/8 mile car, I don't know anyone running anywhere near that much gear. We ran a 5.00 gear in the Camaro with 436" sbc, glide and 29.5x10.5 tires. Turning about 7400 rpm.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios [Re: cudaman1969] #2439041
01/22/18 03:37 PM
01/22/18 03:37 PM
Originally Posted By cudaman1969
[Think about it, tight converter you need that gear reduction.
Not w/ the nitrous on you don't.
CHIP
